Old 02-03-2010, 05:31 PM
quasarix is on a distinguished road
Unhappy Fanuc 18M on DAHLIH VMC-720 Manual/parameters needed
Hello!
If anyone would be so kind to send me a parameter manual in English for Fanuc 18M or/and some basic parameter explanation/list, also would appreciate some tips for setting this machine again all memory is deleted (parameters,etc)
so far i managed quickly to get alarms off but Z axis is inverted and has reverted work range so i can move it only few cm lol, also i dont have mem, mdi modes etc..
Thanks in advance
My email: litex@gmx.net
Old 02-04-2010, 10:01 AM
stevo1 is on a distinguished road
I will dig up the manual to send you but you need more than that. Your option parameters need to be entered. You don’t have a copy of any of them? Your best place to start is to call Fanuc and or Dahlih and give them the serial number of the machine. They should have a backup of some sort for your machine to get you going.
Stevo
Old 02-04-2010, 11:41 AM
ben_heinman is on a distinguished road
Diagnostics and options
Since that is an old machine it won't help to contact DahLih because there file backups went missing along with their computers. If you PM me I can send you a PMC/diagnostic file from 1991 that may help.
Old 02-04-2010, 10:23 PM
machine is made in August 2003 S/N - 3001022101
Old 02-04-2010, 10:25 PM
Hi! i need backup help for MCV720 Dah lih Fanuc series 18-M
its not that old machine, production date is august 2003, i will try to contact dahlih
Old 02-05-2010, 07:42 AM
did you get the manual I sent via email?
Stevo
Old 02-05-2010, 08:00 AM
Yes i got it! Thank you Stevo!
BTW i managed to fix most parameters and machine works almost normal now, but i cannot travel Y ax to zero return point, any tips?
Hopefully manual from stevo will help with that
Old 02-05-2010, 08:05 AM
Any alarms when it stops? I would not think it is referenced if it never made it to the switches.
Old 02-05-2010, 08:39 AM
no alarms, sometimes after i move it with handle then it starts to show overtravel but when freshly started it just stops before without slowing down
Old 02-05-2010, 10:54 AM
That's odd. Does the refernence lights show that it is referenced? It could be something with being so close to the softlimit settings. Is that the alarm you get when you use the handle is "softlimit overtravel"?
It sounds like your softlimit settings are causing you problems. Although usually if you powered up in the overtravel area it would display the alarm right away. These are parameters 1320 and 1321. Write down what they are then adjust them to 999999 and -999999. If the axis still does not move set them back to normal.
Stevo
  #11   Ban this user!
Old 02-05-2010, 11:08 AM
Stevo
I already tried to play with those 2 parameters but that just allows how far you can travel without alarm, but it stops before that when using referent zero return without over travel alert, i think i got idea now but will have to try it tomorrow
Thanks for trying
  #12   Ban this user!
Old 02-13-2010, 10:48 AM
Still looking for possible solution
anyone got ideas?
btw if i do G91 G28 X0 (absolute wont be recalculated right) only works right using Zero return.
Mode switch for Fanuc 10m on a Dahlih 1020mcv davestewart53 Want To Buy...Need help! 2 03-11-2010 09:19 AM
Need Help!- Fanuc 10M on Dahlih MCV 760. Jakes Fanuc 2 01-28-2009 03:06 PM
Dahlih MCV 1020 Fanuc 10m burbankbrewer General CNC (Mill and Lathe) Control Software (NC) 2 06-10-2008 07:10 AM
manual parameters fanuc 6m Olsson General CNC (Mill and Lathe) Control Software (NC) 4 04-01-2007 12:05 PM
Dahlih MCV 1020 Fanuc 10m burbankbrewer CNCzone Club House 0 11-15-2006 10:44 AM
