In my turning center with Fanuc oi mate-TB, alarm "9034 - SPN 1 Parameter setting error" is displaying.... please anyone can help me to fix this problem...
thanks...
thanks...
I looked through the manuals and I did not see anything in reference to this alarm. What kind of alarm is it??? PS, OT, SV etc.
What are you doing when this alarm appears?
Stevo
Usually I see 9034 spindle alarm when start entering parameters in new machine, and automatic parameter setting does not work for particular drive/motor combination.
Are you sure no one played with machine parameters? Start checking all parameters from 4000.
Check if PRM 4019.7 = 1 - if so, that is - parameters for motor model are reset, but the new combination can not be set automatically. Get the backup of your parameters and B-65280 spindle parameter manual and start playing.
If you are lucky with the soft version, diagnostic 720 will tell you the wrong parameter, but this like a lottery... usually it is 0 or does not exist.
Check also PRM 4133 for motor model code - if it is 300 or 400, all the parameters for the spindle should be entered manually.
Post the model or partcode of your Fanuc spindle motor
I'm sure some one here has a copy of the standard parameters for that motor for you to cross reference
Or upload a backup of your machine
*~~Darwinian Man, though well-behaved, At best is only a monkey shaved!~~*
*__________If you feel inclined to pay for the support you receive__________*
*_______Please give to charity http://www.oxfam.org/en/getinvolved_______*
Fanuc spindle motor
Model : β C/6000i
Type : A06B-1445-B200
thank all for your replies...
beta iI 6/6000 is sensor-less type, it should be not A06B-1445-B200, but A06B-1445-B206 or B207
A06B-1445-B200 is beta iI 6/10000
Look for any backup parameters.... or call Fanuc
