Old 01-28-2010, 04:58 PM
zman300 is on a distinguished road
32i doing something strange
32i control on vertical cnc lathe.
Having a problem withe the z axis motor.
Sometimes when you home the machine it works fine.
Sometimes it hits 250% and alarms with z soft thermal.
I'm told the z axis motor is bad.
No problem, under warranty.
It's doing something they can't explain.
You can turn the handle to move the head up and down.
The head doesn't move but, the display says it's moving.
After turning it back and forth a few times it will alarm.
How can that happen.
They don't have an answer for that yet.
Old 01-28-2010, 09:33 PM
MysticMonkey's Avatar
MysticMonkey is on a distinguished road
possibly a faulty brake or power to brake
*~~Darwinian Man, though well-behaved, At best is only a monkey shaved!~~*
*__________If you feel inclined to pay for the support you receive__________*
*_______Please give to charity http://www.oxfam.org/en/getinvolved_______*
Old 01-29-2010, 03:36 AM
CNCZILLA's Avatar
CNCZILLA is on a distinguished road
You need to look at the load on the Z axis when moving it, this will tell you if there is something mechanically wrong or not. Use your manual pulse wheel and move it slowly while watching the load. If your load starts to increase as you move the axis then you have some bindage or something mechanical is wrong. If your load does not go up and you get an alarm then it is probably electrical, I.E. drive or motor. If you want to determine if it is the motor then you will have to get a little deeper in it. You can block up your Z axis so you can diconnect the belt and seperate the motor from the ballscrew. Then use the pulse wheel again and jog the axis you should see the motor turn. If it turns fine with no loads and no alarms then the problem is not the motor. If you have to do this procedure then when you reconnect your belt you will have to reset your Z Zero. This procedure is of course more time consuming and depending on your machine it could be easy or hard. You are basically trying to isolate the components to determine where the problem is. If it is determined to be electrical then swap the drives and see if the problem moves. This will be the quickest test to do first. I would swap the drives first before trying the mechanical check and see, you may get lucky and have a bad drive and not have to get into the mechanical part. This shouldnt take long and you can eliminate that pretty quickly. However if the machine is under waranty then the Distributor service dept should be handling this.
Old 01-29-2010, 07:09 AM
fanuc-support.c's Avatar
fanuc-support.c is on a distinguished road
Does this machine have DCS (dual check safety)? I have seen some software conflicts with this that can cause some strange things to happen.
If not your probably looking at a defect servo amp.
The Fanuc Support Center Team
www.fanuc-support.com
Strange EMC Problems pyrojon LinuxCNC (formerly EMC2) 1 02-27-2009 09:39 PM
New Machine Build- Strange Behavior. riveracnc Mach Software (ArtSoft software) 2 11-28-2008 06:54 PM
VMC 15-XT strange behaviour FinnCNC Fadal 0 03-27-2007 11:03 AM
Strange Request? ALANMAC General CNC (Mill and Lathe) Control Software (NC) 7 11-24-2006 03:54 PM
Looking strange CNCadmin CNCzone Site News and Contests 0 09-15-2005 09:04 AM
