Old 01-28-2010, 10:06 AM
chucker's Avatar
chucker is on a distinguished road
Machine hitting hard in corners
I have a part that has a 2.5 dia hole in it I am using a 3/4 end mill to turn this hole into a 2.515 square I am rampaging down through the square at about 3 deg making 6 passes this is around .05 depth of cut my problem is when I turn the corners the machine thumps really hard in the corners at any feed rate above 60 ipm so bad at 280 ipm that the machine shakes the floor
I have two machine just a like and this same program works great on one but not the other and both machines are in about the same mechanical shape no back lash machines are not loose All the pads are tight to the floor same fixture used on both machines both machines are KIWA”S And both have a Fanuc 18i control is there any parameters that can be adjusted to correct this ?
Old 01-28-2010, 04:36 PM
MysticMonkey's Avatar
MysticMonkey is on a distinguished road
Try Using G62
Fanuc 18i Operators Manual
Chapter 2
Section 5.4.2.1
Related Parameters
7055#0=1
1710
1711
1712
1713
1714
*~~Darwinian Man, though well-behaved, At best is only a monkey shaved!~~*
*__________If you feel inclined to pay for the support you receive__________*
*_______Please give to charity http://www.oxfam.org/en/getinvolved_______*
Hitting the wall in XP Brakeman Bob SolidCam 12 02-05-2010 02:12 AM
Not hitting the logic threshold? yoopertool Stepper Motors and Drives 1 01-17-2010 06:38 AM
Turning Acrylic Hard on the machine?? Gncc50 Glass, Plastic and Stone 1 09-22-2009 02:05 PM
How hard would it be to machine this part? kentrob11 General Metalwork Discussion 3 03-28-2008 01:06 PM
Hard-to-machine thread tex G-Code Programing 30 11-04-2005 12:17 PM
