Old 01-26-2010, 05:27 PM
yumuri is on a distinguished road
how to load a program in fanuc 6t?
i nee to load a program into the memory CNC fanuc 6t-A,hitachi seike
5NE ,does anyone know the steps? ??
Old 01-26-2010, 06:29 PM
CNCRim's Avatar
Hardware tool required:
DNC software
Rs232 cable
inverter
Software required:
check your machine parameter manual for I/O data
go on this webpage http://www.aggsoft.com/cnc-dnc/ and download the setting you need, put the information in the DNC and machine.
Good luck!!
Old 01-27-2010, 01:49 PM
I put The DCN settings,but i can't load the program....
I found the following procedure to load prgram data into the memory (fanuc 6t A) when the number of program numbers is one:
1-set the lock key to write
2-set the mode selector key to Tape EDIT
3-set the control tape to tape reader((((this step i don't know how to do it?)))
4-Press the READ key
5-set the lock key to LOCK.
6-when the RESET key is pressed while in the tape edit mode,the tape is rest to head of the program.
is what I do to cnc, but this does nothing, some people tell me that when the CNC is ready to receive the information of the program, the initial LSK cominezan to flicker but this kind are not to be done.
but some people tell me ,some machine(CNC) when are ready to receive the program the initial LSK start flashing....but i don't nkow when the machine is ready to receive,or something to indicate...
Old 01-27-2010, 05:24 PM
CNCRim's Avatar
Dnc setting link
http://www.connectcnc-dnc.com/dnc-settings.html
Old 02-26-2010, 02:02 PM
samiahmed is on a distinguished road
The same problem
Hi yumuri,
I do the same procedure as you but not thing change!
Did you solve your problem?
thanks
sami
Need Help!- FANUC 31i load program Bama Fanuc 1 04-18-2010 03:22 AM
How Do I Load a Program? ranchak Bridgeport and Hardinge Mills 2 09-04-2009 01:48 PM
Problem- Can't load program to Fanuc 21i-m dpy Machine Problems, Solutions , Wireless DNC, serial port 10 04-09-2009 05:18 AM
Need Help!- Can not load a program via MDI steelhead9 Fanuc 4 01-22-2009 10:31 AM
Doesnt load all of the program? dafowfidy Mach Mill 3 08-06-2008 08:00 PM
