| Hi all! I'm having problem with milling machine: HITACHI SEIKI VA - 55II, controller FANUC 11M. When i start machine, on screen display: FS11M9A ROM TEST : END RAM TEST : END BUBBLE INITIALIZE : END BUBBLE TYPE : 03 BUBBLE PREPARATION : END CHECK LABEL SYSTEM : ERROR Can any one indicate me how to fix this error? Thank! |
| I had discussed this error in another thread before. For reference here is the link to that thread. http://www.cnczone.com/forums/showth...l+error&page=2 It appears that you are going to have to do a master clear of the control. Do you have all of the data out of it? You will need the programs, especially the 8000 and 9000 programs. These have a parameter that locks them so make sure that they get backed up. They will not “punch” out of the control if they are locked. I don’t have my book in front of me but IIRC it is parameter 11.0 for the 8000 and 2201.0 for the 9000. You need to also backup your machine parameters. You will then need your PMC parameters, timers, counters, keeprelays etc. These will not “punch” out of the control like the programs and parameters do. You will need to write them down. Attached is a blank data form I use for this control. Now do the procedures below. At the 2nd procedure you will need to take your option parameters and put them in hexadecimal format. That is the way they are entered. If you need me to put them in a spreadsheet that converts them send them to me. 1st To do a master clear power on with "7" and "9" depressed IPL screen will appear press "99" "Input" clear "Y" then it will ask you axis. This is the number in #9000 next it will ask you option #1? press "Input" Press "Input" through all options. Should only be 32 options It will ask to clear data or memory hit "Y" Then select option "6" to exit IPL 2nd To enter in option parameters 1) Power up machine with "-" minus and "." decimal point depressed 2) Key "99" and "Input" 3) Key in "3" or whatever # axes in parameter 9000 @ "AXIS" prompt 4) Step through options by number and key new Hexidecimal codes and "input" option 1=9100, option 2=9101 ect. Just push input if no change is required 5) If "clear files" appears, hit "Y" - will erase programs etc. 6) When 1st menu appears, key "6" and "enter" Your CNC will come up. Then enter in your PMC data. Set up your communication parameters, then download your parameters and programs. Stevo |
| tl-2 program integrity error and program data error alarm #'s 212 250 need help | CNChelp | Haas Mills | 12 | 03-14-2010 08:19 PM |
| Need Help!- Matsuura Mc500v seq error/magazine error | mc500v | General Metal Working Machines | 10 | 01-08-2010 01:35 PM |
| Need Help!- Error 414 Z axis error detect- servo alarm | andywids | Fanuc | 0 | 07-09-2009 10:33 AM |
| Need Help!- Error 414 Z-axis error detect servo alarm | andywids | General Metal Working Machines | 1 | 07-09-2009 09:56 AM |
| Offset Chain Milling vs Path Milling | ynnek | TurboCAD/CAM | 1 | 03-11-2009 05:29 PM |
