Old 01-23-2010, 07:42 AM
chipsahoy is on a distinguished road
Engagement of Inches Per Revolution
Hi all
Seem to encountered a problem.. Recently re loaded my PCM Parameters..
Everything is up and running.. What I am noticing is that im not engaged when I run Inches Per Revolution.. On the "check screen" it shows running say .006 IPM, but I can over ride the feed and that shows in FPM.. Bottom line one knows when they are engaged properly because you can override the spindle and the feed will slow down or speed up in relation..
I appreciate you comments..
Chips
Old 01-23-2010, 09:50 AM
dcoupar's Avatar
Do you mean if you turn the spindle override down to 0, the axes keep feeding? I was confused by "I can over ride the feed and that shows in FPM".
AFAIK, the ACT.F is always shown in inches or MM / minute.
Old 01-23-2010, 11:42 AM
Yes it keeps on feeding.. It should slow down or speed up when you adjust the spindle..Also the Feed switch should have effect when in IPR mode.
What do you think ??
Old 01-23-2010, 01:46 PM
dcoupar's Avatar
The feedrate override switch should work in either IPM or IPR. If you turn it down to 0, it should stop the feed.
If you're feeding in IPM (G98), the spindle speed override won't have any effect on the IPM.
If you're feeding in IPR (G99), the spindle speed override should vary the IPM accordingly.
What model control is it?
Old 01-23-2010, 01:54 PM
Al_The_Man's Avatar
If this is no G96 you may have missed a 900 or 9000 option parameter entry.
Old 01-23-2010, 02:59 PM
Control is 10T fanuc
Here is how im programed
O0001 (2 1-22-2010)
N1 ( FINISH FACE FACE1_1)
G0 G20 G40 G54 G80 G99
G28 U0 W0
T0101 ( SW_FACE_80_RH)
G50 S1000
G97 S1000 M3
X2.9 Z0. M8
G1 X-0.0625 F0.006
X0.1231 Z0.0928
M9
G28 U0 W0
M1
Also here are my 9000 parameters
i have no 900 parameters
N8000P00000000
N8010P00000000
N9000P2
N9001P2
N9002P16
N9100P00001011
N9101P00001000
N9102P00101111
N9103P00001000
N9104P00000101
N9105P01000111
N9106P01100000
N9107P00000011
N9108P10101011
N9109P00001000
N9110P00000000
N9111P00000001
N9112P00000000
N9113P00010000
N9114P00000000
N9115P00000000
N9116P00000000
N9117P00000000
N9118P00000000
N9119P00000000
N9120P00000000
N9121P00000000
N9122P00000000
N9123P00000000
N9124P00000000
N9125P00000000
N9126P00000000
N9127P00000000
N9128P00000000
N9129P00000000
N9130P00000001
N9131P00000000
Chips
Old 01-23-2010, 03:01 PM
What parameter is at start up that makes sure its in IPR..
Are there options??
Also what shouild it be??
Cheers !!
Old 01-23-2010, 03:07 PM
What does 9130 Parameter do.. ?? I do see a difference from my factory settings
Chips
Old 01-23-2010, 03:10 PM
Al_The_Man's Avatar
Well your G96 is enabled according to your parameters.
I always thought G97 was constant surface speed cancel?
Don't you want G99? feed per rev?
Old 01-23-2010, 03:48 PM
Al
Yes I do want G99 "FEED PER REVOLUTION"
Please explain what I have wrong??
What must I change !!
Did you see my post on the program example..??
Chips !!
  #11   Ban this user!
Old 01-23-2010, 04:08 PM
Mistake on the last entry..
Im trying to get "Inches per revolution".. IPR
example
.006 chip per rev
  #12   Ban this user!
Old 01-23-2010, 10:37 PM
dcoupar's Avatar
Your program looks fine.
G99 (FEED PER REVOLUTION) is active.
G97 (CONSTANT SURFACE SPEED CANCEL) is active
F0.006 should feed at 0.006 IPR X 1000 RPM = 6.0 IPM with overides at 100%.
What happens in this program if you turn spindle speed override down to 0%? Does X still feed to -0.0625?
I don't have an option list for the 10T, so I can't tell you what 9130 does.
Steps per revolution scrambled Mach Software (ArtSoft software) 2 12-15-2009 12:36 AM
Just IN- The Peddinghaus REVOLUTION ANGLEMASTER Peddinghaus2 Product Announcements & Manufacturer News 0 10-31-2009 09:26 AM
Problem- Trunion table - brake engagement flashno Haas Mills 4 05-24-2008 06:32 AM
Inches and mm jorgehrr Solidworks 8 02-04-2008 03:43 PM
Calculating steps per revolution watsonstudios Mach Software (ArtSoft software) 1 06-25-2007 01:22 PM
