New guy here. Have been running cnc vertical lathes with the 18-T control for many years. Very good control Just got in a new vertical lathe with the 32i control. They are so much different than the 18-T. An example. When setting tools in the geometry offsets. On the 18-T machine the X offset for a boring bar is -31.000. With the same bar in the 32i machine the X offset is -.75. I want to know .75 from where. The person doing the training couldn't tell me. That .75 makes no sense, to me anyway. ![]() Is this the way this control works or can parameters be changed to make it measure offsets like the 18-T. Can anyone tell me. Thanks!! |
| When you "home" your old machine, it probably shows zero for the X and Z machine position. Your new machine probably has some pretty big numbers in the X and Z machine position at home. The new one can be changed, I'm sure, to more closely match the old machine. If you look at parameter #1240 on the old machine it probably has 0 for X and Z. When you home the machine it sets the machine position to these values. Now compare the values in parameter #1240 on the new machine. You'll see a metric equivalent of the values displayed for machine zero. If you've never changed parameters before, I'd call the "person doing the training" (if the machine is new, they should make it work like the old one for you). |
| That appears to be it. The new machine is X1099.82, Z985.52 We are used to the old machine. Easier on the operator if they all work the same. Which way do you prefer. Thanks
| My guess would be you're not using G54 thru G59 for "fixture offsets". Most lathes only use them for adjusting the Z work offset (or shift). Did you check parameter #1240 yet? --- oops you must have been typing at the same time I was. All of the machines I've set up over the past 5 years were like your new machine, so that's what I'm used to. But it's your machine, and you should have it work the way you want it. Is this a new machine? |
| No don't use the G54-G59 on the lathes, only on the machining centers. I wasn't thinking machining center so the fixture offsets threw me. Now it make sense. Yes it's a new machine, Doosan VT1100. The old machines are a 99 Doosan V850, 96 Okuma & Howa V80R. Both are good machines. We do mostly vertical turning. I grew up on Bullard manual VTL's. Thanks for your help. |
#10
| On the work coordinate screen, do you see zeroes as EXT Offset values? You should select the same coordinate values at reference position (parameter 1240). These are in least input increments, e.g. 450000 for 450 mm. |
| Need more tool offsets | ChattaMan | Okuma | 16 | 12-07-2009 05:36 PM |
| Tool offsets | ChattaMan | Okuma | 3 | 05-18-2009 12:30 PM |
| setting the tool data and the tool offsets | Michael82 | Mazak, Mitsubishi, Mazatrol | 6 | 01-23-2009 01:50 AM |
| Tool offsets | Clemmie | Haas Mills | 21 | 12-21-2006 01:24 PM |
| Tool offsets | plateroomred | CamSoft Products | 7 | 05-28-2005 02:43 PM |
