| It's the information the PMC uses to run. The tables that contain this data can be found under system > PMC > PMC > PRM You have just reloaded the PMC parameters.
__________________ The Fanuc Support Center Team www.fanuc-support.com |
| Timers = they are timers in the PMC. i.e if you use hydraulic clamps, you might want a 0.5 - 1 second delay to make sure pressure is there. Counters - rarely used, but them simply count up, tool life etc. Keep relays - (K0.0-K30.0) they are used to make somethings in the pmc switchable, bit like a push button on the panel. Set the keep relay to 1 and its on, 0 is off. Data table - this is used to store binary, hexidecimal and bcd values, normally the results of calculations or checks made in the PMC. |
| Need Help!- G71 explanation | chipcrazy | G-Code Programing | 1 | 08-25-2009 01:47 PM |
| G17, G18 and G19 explanation please | cossiegaz | G-Code Programing | 19 | 06-23-2009 04:44 PM |
| Need Help!- G41 and G42/40 explanation | noshoesnoshirt | G-Code Programing | 3 | 05-09-2009 11:57 PM |
| G64 & G61 Explanation Please | weaston | G-Code Programing | 1 | 01-31-2007 04:34 AM |
| CNC explanation | Alex S.A | General Metal Working Machines | 2 | 10-01-2004 12:23 PM |
