| We have a Hyudai 180 with the Oi-T controller. I would like to true up the boss that the chuck originally sat on. Can someone tell me how to enter a speed & get the spindle end of the lathe turning so I can handwheel slowly to true this boss up. This boss is .007 out or round while the piece it bolts to is dead on. Thank you. |
| Dave….yes you are correct my apologizes. I usually use G96 however I have a G92 for max speed programmed right before it. And as always a lot of these safe settings I have long programmed them into macros and tool calls etc etc that way things like this are less likely to happen. Bad habits….anyway thank you for the correction. Stevo |
| I tried that & it still didn't work. Our machine has been modified slightly & something in the controls may have been used for another function because it tells me the chuck is not closed & we don't have a chuck on the machine anymore. |
#10
| There may be a proximity switch or two on the actuator that tells the control the chuck is open or closed. Check these. Also, there may be a OD/ID chucking switch. You might try changing this and actuating the foot pedal to see if the chuck clamp lamp illuminates. |
#11
| On my kia with oi-t ...G97s1000....end of block .....cycle start ...then enter m03 end of block...cycle start....spindle should come on.....for some reason m code has to be on seprate line from g-code...on my new machine....give it a try... |
| Hyundai VMC | kevinkoons | Hyundai Kia machine | 1 | 03-30-2009 12:27 PM |
| hyundai kia | mekdad | Suggestions for the CNCzone.com site. | 3 | 12-23-2008 01:34 PM |
| Newbie- Hyundai SPT-V30 | kevinkoons | General Metal Working Machines | 6 | 03-03-2008 09:09 AM |
| cnc controlled mandrel bender controlled by mach3 | timmyb199 | Bending, Forging,Extrusion... | 5 | 05-30-2007 06:35 PM |
| hyundai hit 8 | drill | General Metalwork Discussion | 4 | 10-06-2005 07:38 PM |
