Old 01-13-2010, 04:28 PM
Brad-B1 is on a distinguished road
Post Block Skip on Fanuc
I have a Fanuc Series 31i Model A5 controller and would like to be able to turn the block skip off in my program. Does anyone have the code?
N45T6M6H6(1.00 BORE)
N50G0X0.Y0.
N55W1.0Z0
N60G87G95W-1.25R.2F.002Q.005S900M3M8
N65G80G94
N70M0
/N75GOTO50
N80M5M9
N85G53W-10.Z0.
N90 ??** Turn Off Block Skip **??
N95T76M6H7(.750 BORE)
Old 01-13-2010, 05:12 PM
MysticMonkey's Avatar
MysticMonkey is on a distinguished road
Some MTBs insert M-Codes into their machines
This is all handled via the ladder
If you do not have these m-codes - ask the company you bought the machine from
*~~Darwinian Man, though well-behaved, At best is only a monkey shaved!~~*
*__________If you feel inclined to pay for the support you receive__________*
*_______Please give to charity http://www.oxfam.org/en/getinvolved_______*
Old 01-13-2010, 06:36 PM
beege's Avatar
beege is on a distinguished road
N50G0X0.Y0.
N55W1.0Z0
N65G80G94
N70M0
/N75GOTO50
N80M5M9
N85G53W-10.Z0.
I don't think most machines turn off your block delete switch from within a program. A different solution might be to use a variable at N75:
IF [#500EQ1]THEN GOTO50
and you can reset that in the program at N90 to:
#500=0
There are tons of other ways to address this, but I think that most machine suppliers aren't going to give you what you are looking for without $$$$
Old 01-13-2010, 09:13 PM
psychomill is on a distinguished road
Yep... Most don't.. some do. The builder writes that in so that you can turn skip on/off ... Some even so that you can turn multi-block skip on/off (like /2, /3, /4, etc.)
No "standard" code though...
It's just a part..... cutter still goes round and round....
Old 01-16-2010, 05:42 AM
sinha_nsit is on a distinguished road
Block-skip is useful if Custom Macro B is not available on a particular machine. I believe, new programs need not use block-skip function; Custom Macro B gives more flexibility and convenience. In fact, block-skip function may, sometimes, cause confusion:
#1 = #2 / 2;
If block-skip switch #2 is ON, this may be interpreted as
#1 = #2
Hence, I usually program such codes as
#1 = [#2 / 2];
which is always interpreted as DIVISION.
block skip switch operation sinha_nsit Fanuc 8 04-28-2009 02:59 AM
Block Skip missing Scanfab Fadal 0 03-13-2009 11:39 PM
Programming part variations with block skip kmuller PTC Pro/Manufacture 3 09-18-2007 04:36 AM
Block skip function Vern Smith Haas Mills 6 07-31-2007 07:50 AM
Removing the block skip / Shizzlemah Fadal 2 02-17-2006 10:01 AM
