Old 01-12-2010, 11:15 AM
yumuri is on a distinguished road
Question Baud Rate for Fanuc System 6T
I need to know the baud rate in Fanuc 6T.on Cnc Hitachi seiki 5Ne 11000,using mastercam program.
thanks in advance.
Old 01-12-2010, 12:25 PM
CNCRim's Avatar
You need to check the machine want to communicate with it's under In/Out page, and you can setting your DNC match that number, I don't think anyone can tell you what the machine is have.
Old 01-12-2010, 12:45 PM
Al_The_Man's Avatar
Check parameters 0024 & 0025.
0024 is bit 0 = 0 is 1 stop bit, bit 0 = 1 is 2 stop bits.
0025 is the baud rate 2400 baud is 11001111, 4800 baud is 11101111.
Old 01-12-2010, 02:36 PM
tHANKS, Mr.AL. WAS VERY helpful !!!! KNOW IF IS POSIBLE, I have doubts on the communications of Mastercam (Pc) to the machine, ...How to know the
1.FORMAT (THE OPCIONS ARE : ASCI,EIA,BIN)
2.PARITY (THE OPCIONS are: Odd,Even,None)
3.Data Bits(The opcions are:6,7,8)
4.Handshaking(None,sofware,Hardware)
Thanks again!!!
Old 01-12-2010, 03:00 PM
Al_The_Man's Avatar
This may help also.
Try this program.
http://www.cadem.com/free_dnc_drip_f..._machining.htm
Old 01-14-2010, 01:11 PM
cnc-it's Avatar
cnc-it is on a distinguished road
The max baudrate on Fanuc 6 is 9600.
John.
What RS232 baud rate do you use? and why? gar Haas Mills 68 03-08-2011 09:32 AM
Need Help!- Getting higher baud rate in V23 kbspeed BobCad-Cam 1 08-11-2009 03:54 PM
Whats Maximum baud rate on an OM-D meadowtech Fanuc 4 02-20-2009 11:17 PM
Problem- V-22 baud rate qualitytool BobCad-Cam 0 10-20-2008 08:11 AM
Fanuc O-T baud rate ttorqueshop Daewoo/Doosan 6 12-13-2007 12:57 AM
