| You don't use the "Start" button to input the values, only to run them once input. We have one 6T control in our shop and it is programmed by the other programmer, so it has been a while since I have been on the control. There should be an "Insert" key. If not that , then an "Input" key. May have to press the far right (or possibly the far left) soft key to bring up the right command to insert. Pretty sure it is "Insert" not "Input". Believe it is "Input" on an OT control. |
| First you have to be in the COMMAND input screen, With your mode selector turned to MDI press the "COMMAND" button then the "PAGE DOWN" button, enter your command then push the "INPUT" button then the "START" button. Jerry |
it works!!!thanks a lot!!!and know i try to find out All the programs into the memory machine,do you know how get them? |
| mori seiki mv junior "jog rset" error | Arsonist | General Metal Working Machines | 10 | 03-24-2010 06:45 PM |
| Need Help!- fanuc 6T "HITACHI SEIKI" | yumuri | Fanuc | 4 | 10-31-2009 10:38 AM |
| Need Help!- "motor steps per resolution" and "driver microstepping" settings | margni74 | LinuxCNC (formerly EMC2) | 9 | 10-24-2009 02:33 AM |
| "J" head type "millport"(tiwan,1980) clutch | marksbug | Bridgeport and Hardinge Mills | 1 | 08-17-2009 10:48 AM |
| Need Help!- Mitsui Seiki VR5A orientation "Feed Hold" 6M | woonsteel | Fanuc | 4 | 05-01-2009 08:39 AM |
