Old 01-07-2010, 05:46 PM
Wroughtbit is on a distinguished road
alarm 561 Fanuc OT
We have a 1993 Tsugami S16D lathe with Fanuc OT control. We are getting this alarm on start-up. ( 561 OVER TRAVEL : -6 )
Would like to have a OT manual if anybody has one.
Thanks for any help you can give.
Old 01-07-2010, 06:14 PM
dcoupar's Avatar
This information is from the 0T-C parameter manual.
That alarm indicates the 6th axis has exceeded the - side of the stored stroke check 1 or 2. I'm not sure what the 6th axis is on a Tsugami S16D, but I believe you can check parameter #7130 to see what the name assigned to the 6th axis is.
Parameter #0065 bit 3 sets whether or not a stored stroke check is performed before reference position return operation (Zero Return) is performed. It may be as simple as changing this parameter from 0 to 1 or from 1 to 0.
Old 01-07-2010, 07:54 PM
Thank you dcoupar for the reply. parameter 7130 says 49. parameter 0065 says 0. It did not help changing it to 1. I also noticed some of our parameters do not match the paperwork with the machine, and some of them are flickering between 1 and 0. I was repairing the spindle locking pin air cylinder with the machine on. Maybe I was confusing the magnetic sensors and timers?
What would cause the parameters to change?
I am going home now. Hope to hear back tommorow.
Old 01-07-2010, 10:38 PM
CNCRim's Avatar
Check you approcimity switch, it could be damage.
Old 01-07-2010, 11:34 PM
fanucman is on a distinguished road
power up holding Cancel and P..
do a reference return you should be good
Old 01-08-2010, 10:26 AM
Thanks Guys. This machine has no limit switches, just stroke limits.
I can still jog all "jogable" axis. Both the "T" axis are about in the middle of their strokes. Position #'s look good.
What will holding Cancel and P do to the control?
How do I do a reference return after Cancel and P?
Old 01-11-2010, 06:42 PM
MysticMonkey's Avatar
MysticMonkey is on a distinguished road
P/Q Cancel overrides the stored stroke check (Software limits)
allowing you to reference the machine past the safe position stored in the parameters.
the error occurs sometimes if the machine moves with the power off and 'forgets' its position. Or if the encoders are removed and powered off
*~~Darwinian Man, though well-behaved, At best is only a monkey shaved!~~*
*__________If you feel inclined to pay for the support you receive__________*
*_______Please give to charity http://www.oxfam.org/en/getinvolved_______*
Old 01-12-2010, 09:56 AM
Thanks to everybody that responded to this thread. Who do I send money to? This site is great!
The alarm was because the "T2" axis (or the 6th axis) had fallen about
.2900" in the negative direction, the stored stroke is all in a positive direction. Just had to manuaully move axis to a positive position and hit the reset button.
alarm 408 servo alarm "serial not RDY", αP18 fanuc mtor code sting Fanuc 0 01-01-2008 09:03 AM
Fanuc 18m alarm 444 swartling Fanuc 3 07-25-2007 11:27 AM
Fanuc 446 Alarm blakester Fanuc 17 03-30-2007 02:57 PM
Fanuc 3t alarm 087 booster05 Fanuc 12 11-14-2006 06:18 PM
Alarm 421 on Fanuc 6M vfsi Fanuc 2 05-12-2006 10:44 AM
