Old 01-06-2010, 02:45 PM
jdr1961 is on a distinguished road
Fanuc-18T G73 Cycle definition
When defining the part profile for the G73 Pattern Repeat cycle, is it okay to use the angle, chamfer and radius addresses (,A ,C ,R) or must it be done using G1, G2 and G3?
The machine is a Hardinge GT-27 lathe with Fanuc-18T control.
Thank you for any help!
Old 01-06-2010, 03:29 PM
dcoupar's Avatar
According to the 18T-B manual, you can use chamfering and/or corner rounding, just not in the last block of the definition.
Name:	18T-B G7x Chamfer Error.jpg‎
Old 01-07-2010, 01:52 AM
sinha_nsit is on a distinguished road
On 0i control, it is not permitted. I was under the impression that the standard G-codes work the same way in all control versions. At least in this case, there is difference (or do we have to again interpret the language of Fanuc manuals!). From 0i TC Operator's Manual (Section 13.2.8, page 158):
8. The blocks between the sequence number specified by P and Q on the multiple repetitive cycle must not be programmed by using "Direct Drawing Dimensions Programming" or "Chamfering and Corner R".
Need Help!- FANUC 10T G76 cycle DanilGrip Fanuc 10 03-03-2010 07:51 AM
G73 Cycle on Hardinge GT-27 / Fanuc-18T jdr1961 Hardinge Lathes 1 01-06-2010 03:33 PM
Fanuc OT-C and G71 Cycle rrbmachining Fanuc 7 11-24-2009 04:55 AM
G78 threading cycle on Fanuc 0i-TD Deco-Doctor G-Code Programing 3 01-06-2009 11:35 AM
repetitive cycle on Fanuc 21 TA DHYSTA Fanuc 11 08-16-2007 08:46 PM
