Old 01-05-2010, 07:05 AM
shas595 is on a distinguished road
Exclamation Memory Clear / Reset
I am having a problem with communications for my machine. It is a Hitachi Seiki HT20SIII with Seicos L Multi control. I was told there is a way to clear the memory by pressing 2-3 buttons upon startup. Does anyone know how to do this? If you need more information see my other posts. I am still having the same problem.
Old 01-08-2010, 12:23 AM
fanucman is on a distinguished road
what problems are you getting.. clearing memory probably wont help
Old 01-08-2010, 05:58 PM
Basically, someone hit emergency stop while i was sending a program to the machine. Now when I start the machine and go to the sned/recieve screen, all of the communication parameters are blank, all of the programs are gone, and once i am in that screen, no matter what button i push, the machine freezes up and I have to shut it down.
Old 01-08-2010, 11:12 PM
what kind of controller is this.. did u get a ps 101 alarm or something?
Old 01-08-2010, 11:25 PM
Its a Seicos Multi controller. And when I power up the machine, there are no errors at all. Everything functions a it should, which is odd. I cant imagine what the problem is
Old 01-08-2010, 11:44 PM
The Engine Guy's Avatar
The Engine Guy is on a distinguished road
On my Fanuc controllers if the control is powered down for example E stop when the LSK/input is flashing on screen (ie loading a program) the parameters and programs are deleted so if as you say the parameters are blank that`s most likely what`s happened I think.
Re-loading the Parameters (They were backed up somewhere???) should do the trick.
Old 01-11-2010, 08:29 AM
I got it solved. I had a guy come over and show me what to do. He adjusted some control knobs on the board in the back, did the memory reset, and set it up so it wont happen again. I tested it, and hit E-Stop while inputting, and nothing happened. So i am all set and don't have to worry about my clumsy friend. Why couldn't they do that in the first place???
thanks for the help
Tags
communication, fanuc, hitachi, multi, seicos
FANUC MEMORY CLEAR & PRECAUTIONS CHANDRU Fanuc 4 05-12-2009 12:16 PM
Help with clear finish trooper55 WoodWorking 11 03-05-2009 06:35 PM
Need Help!- 3D Area Clear TZ250 BobCad-Cam 4 02-19-2008 10:29 AM
How do I clear my cookies? CNCadmin CNCzone.com FAQ 0 10-22-2007 02:33 PM
How do you clear variables after the prg. is done?? theemudracer Fanuc 18 03-25-2007 09:21 PM
