Old 01-04-2010, 04:31 AM
ChattaMan is on a distinguished road
Z Axis error
Control is Fanuc O-MD on a Yang SMV1000.
At power on the control gives an alarm:
434 servo alarm: Z AXIS DETECT ERROR
When looking at the Z axis servo amp in the electrical cabinet, the digital status display is giving alarm code #2.
We don't have any manuals for this side of the machine, only for the control.
Alarm 343 says refer to DIAGNOS No. 720/727
Any ideas?
Old 01-04-2010, 05:34 PM
MysticMonkey's Avatar
MysticMonkey is on a distinguished road
Alarm 434 = Check Diagnostics 720 & 727
Alarm 2 = (LV) Low control power voltage
Check across each phase for 415V
EDIT ***
Sorry I forgot, your mains power might be different to 415
*~~Darwinian Man, though well-behaved, At best is only a monkey shaved!~~*
*__________If you feel inclined to pay for the support you receive__________*
*_______Please give to charity http://www.oxfam.org/en/getinvolved_______*
Old 01-04-2010, 09:59 PM
fanucman is on a distinguished road
alarm 2 is a low voltage alarm.. check the power to the servo drive, also is this they type of amplifier with a little gray door on the front that opens sideways?
if yes then check to make sure that there is 5 volts on the jumper pins..
if no then it should be the alpha series of drives which means check the power to power supply
Old 01-05-2010, 01:29 PM
ben_heinman is on a distinguished road
Low voltage
May be a capacitor problem. Try turning the machine on for 5 minutes so that the alarm is on. Turn the main power off and then back on again. If the machine comes ready then you most likely have a faulty capacitor in the Z axis drive.
Old 01-05-2010, 02:16 PM
3 replies sound similar. Service guy couldn't get today....all snowed in!
Machine is 10yrs old. Pic of amp below.
Thanks.
Need Help!- Error 414 Z axis error detect- servo alarm andywids Fanuc 0 07-09-2009 10:33 AM
Need Help!- Error 414 Z-axis error detect servo alarm andywids General Metal Working Machines 1 07-09-2009 09:56 AM
X axis error on a 325 BugEyedValiant Tree 6 07-05-2009 06:21 PM
Need Help!- 353 OL Z axis error lostkoss General Metal Working Machines 8 11-26-2008 07:46 AM
X axis Error Prboz Mach Mill 3 05-26-2007 06:05 PM
