| Hmmm..Where did you get that from? G90 is for absolute mode and the opposite of that is G91 for incremental mode. They don’t have anything to do with the G71 canned cycle mode. Well they will affect the outcome of the code but relate nothing to a canned cycle. Well let me rephrase that. I have seen them on G-code system "A" under cutting cycle A but IIRC this was for threading and I don’t recall seeing this for the 20 series control. I could be wrong. Anyway G71 should be a valid code on your control but only when using G-code system A or B, not C. Attached is an example of a G71 cycle from the programming manual. Stevo |
| My apologize guys I stand corrected. Sorry for posting misleading info. I should have done a bit more DD before posting. Here is the G90 that says outer/inner diameter turning in G-code system “A”. I have never used it before and would be curious to see an example of it. Stevo |
G0X2.2Z.1 G71U.2R.05 G71P1Q2U.005W.005F.008 N1G0X-.0312 G1G41Z0F.002 X0 G3X2Z-1R1 N2G1G40X2.1 It for rough out complex part... all you need is program finish path, G71 will do the rough cycle. Alot less program that way, and less programming mean less mistake equal to less crash.
__________________ The best way to learn is trial error. |
| See the attachment for more details about G71 Type I cycle. G71 does not use radius compensation, so there is no point in commanding G41/G42 between P/Q blocks. G70 does use it. But a better way would be to command G41/G42 just before calling G70. |
| spindle motor and spindle control dont work | customcncparts | Milltronics | 0 | 10-01-2009 02:08 PM |
| What CNC control is best for prototyping work? Centroid, ProtoTRAK, Siemens, Fanuc ?? | squale | General Metal Working Machines | 4 | 10-13-2008 08:06 PM |
| Newbie- Work Planes / Work Coordinates | MICFDI | Esprit | 9 | 05-11-2008 11:35 PM |
| Problem with work offsets and Acromatic control | acromastic | CamWorks | 3 | 06-26-2007 03:18 PM |
| Best pc based control for 3d work ? | DavyD | General CNC (Mill and Lathe) Control Software (NC) | 20 | 12-20-2005 05:01 PM |
