| G90 is a turn/bore cycle. turn example. starting with a 5" part turn down to 4.9" length 1". GO X5. Z.1 G90 X4.9 Z-1. F.01 this command will do the same as these moves G0 X5. Z1. G0 X4.9 G1 Z-1. F.01 G1 X5. F.01 G0 Z.1 Now that saved some typing, but there is more... GO X5. Z.1 G90 X4.9 Z-1. F.01 X4.8 X4.7 G0 G28 U0 W0 M5 This example will continue cutting by the value specified. This can save typing, make programs shorter, easier to read. The downside is at the end of each cut, it will feed up to 5". This can be a waste of time. A G71 would work better in some cases. Regards, Ken |
| See the attachment for more info on G90 which can also be used for taper turning with an R-word. Yes. Because of radial retraction at feedrate, subsequent calls of G90 become inefficient. In such cases, change the radial position of the start point after a few calls. G71 may be an option. |
| Here is a control similar to yours, this is a tool builders manual. http://www.snkamerica.com/Prod-pdf/G...tor_Guide2.pdf What would help you a lot is a fanuc operator's manual for your specific control. They can be ordered from fanuc, but I don't know the cost. |
| canned cycle for lathe with fanuc control | JPann | G-Code Programing | 6 | 09-27-2011 12:45 PM |
| Newbie- Canned Cycle - Fanuc oi | Trevorweb | G-Code Programing | 6 | 03-12-2009 09:08 AM |
| Fanuc Canned Cycle MACROS | kuyohtay | Fanuc | 9 | 05-20-2008 03:40 PM |
| G90 (Canned turning cycle) Fanuc 21i-TB ? | Jdavis733 | G-Code Programing | 0 | 01-23-2008 08:18 PM |
| Canned Cycle G73 Om Control Fanuc(drill) | marrieche | Fanuc | 1 | 03-05-2007 04:51 PM |
