Old 12-22-2009, 07:22 AM
Aaron 1874 is on a distinguished road
15i-M display problem
Hi everyone !!
I was editing a program when out of the wild blue yonder a " Sub Menu " screen appeared on top of the program i was editing. I must have double keyed something on the keypad ? It will not let me select anthing and I cannot get it to dissapear, hit every key, reset, turned CNC off, still there but only in the ' text ' menu. Sorry to bother everyone with the little stuff, but this is a first for me. The CNC is a Monarch 175B VMC 3-axis Fanuc 15i-M control. Going after the Maintenance Manuals now. Thanks !!
Old 12-22-2009, 04:49 PM
mty_cnc is on a distinguished road
Try pushing "SHIFT" and "8" button at the same time
Old 12-24-2009, 06:44 AM
Sorry about this one guys, this was the first time for me on a newer control and it's all in the operators manual. I thought it was one of those hidden keys that Fanuc doesn't tell anyone about. Thanks !! mty cnc
Old 12-28-2009, 12:57 PM
stevo1 is on a distinguished road
So what was the trick or combo of keys to get the menu off of the screen??
Stevo
Old 12-29-2009, 11:40 AM
OK, here it is on page 499 in the operator's manual " 15i Model B " vol 2 of 2
( GZF-63784EN-1/01 ) june 2002 .
SUB SCREENS
Select the page you want the sub screen to be on ie. pos, prog, check, ect...
it will only be visible on this page, it's not modal.
Press "shift" then "1" keys and the "sub screen menu" will appear.
Use the up and down "arrow" keys to select where you want to get sub menu info from.
1: ACTUAL POSITION
2: PROGRAM
3: TOOL OFFSET
4: WORK ZERO OFFSET
5: CUSTOM MACRO
6: MODAL
7: DI SIGNAL
8: DO SIGNAL
9: SERVO ERROR
10: ALARM
11: OPERATOR MESSAGE
You can easily find your way around with the option keys just below the main screen
to set it up.
When finished press " select / end " .
At anytime you want to get rid of the sud screen press "shift" then " 8 " OR
" shift " then " 1" then " close / screen "
For the guys doing Macro programming this could be helpful to see info related to those
" common variable's " . One draw-back is finding a place to position the sub screen so as not to interfere with other need to see data.
Hope this helps
Old 12-29-2009, 01:20 PM
I have a 15 series that sometimes pops these menus up when the operator accidently hits a combo of keys and I never bothered to look up the fix.
I really only asked so that there was a solution posted in the thread. It helps when doing a search in the forums for a solution.
Thanks,
Stevo
CRT/Display, '91 VF1 TheArmoury Haas Mills 0 11-04-2009 10:57 AM
Need Help!- m-2 display problem elmmachine Mazak, Mitsubishi, Mazatrol 0 08-27-2009 10:48 AM
Anilam Series GX-M Display Problem ZDR-NGinEar General CNC (Mill and Lathe) Control Software (NC) 0 08-08-2008 08:04 PM
Table display problem SScnc Mach Mill 2 08-04-2008 12:44 PM
Problem with OM Monitor/Display darrylh Fanuc 0 01-13-2006 06:04 PM
