Results 1 to 3 of 3
Thread: Communication Input / Output Program SEICOS MULTI
    Registered shas595's Avatar
    Dec 2009
    Exclamation Communication Input / Output Program SEICOS MULTI
    I am having a communication issue with a Hitachi Seiki HT20SIII with Seicos Multi Control (1996). What had happened was, while I was sending a program to the machine from my computer, and the transfer was still in progress when someone accidentally hit the "emergency stop" button. I restarted the machine, but now when I go into "Edit" mode, and no matter what I choose (send, recieve, etc...) it shows the usual screen, but it has no programs listed, no communication parameters (Baud rate, RS232C, etc) are listed. So if I try to input a progam, instantly the whole thing freezes, and I hear a 'CLICK' coming from the back of the machine. You cant do anyting after that, no buttons work at all. If you have any idea, please help me out. If you need more information let me know and I will update my post.
    Edit/Delete Message
    Feb 2006
    From what your saying, it sounds like the settings or memory got messed up. If your not seeings anything for a baud rate (not just the wrong baud rate) then I would imaging you have a pretty serious problem if you do not have a full SRAM backup.
    Check with Mori Seiki service (took over for hitachi-seiki America) or a service company that specalizes with hitachi machines. (Empire CNC is one)
    Dec 2009
    I was hoping it wasn't gonna be something serious. I will try to call them and see what they say. Thank you for the response.
  1. Need Help!- Send/receive program without output/input push
    By padobranac in forum Fanuc
    Last Post: 10-20-2010, 10:53 AM
  2. Need Help!- Communication Input / Output Program SEICOS MULTI
    By shas595 in forum General CNC (Mill and Lathe) Control Software (NC)
    Last Post: 12-21-2009, 09:14 AM
  3. Problem- Hi Cell 23 Seicos L Multi Controller
    By Tung Ngo in forum General CNC (Mill and Lathe) Control Software (NC)
    Last Post: 09-24-2008, 04:31 PM
  4. new control board wiring: multi-voltage input
    By nicanor76 in forum Stepper Motors and Drives
    Last Post: 07-19-2008, 05:49 AM
  5. program input/output with RS232 port on Mitsubishi 50L
    By Chuck Reamer in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 02-04-2008, 03:56 PM
