Hi everyone, this is my first post. Hope to spend time every day here. We have a 2007 Monarch 175B VMC with a Fanuc 15i-M controler I/O to a Fanuc Handy File that is storing files from the CNC as .dat instead of .txt . We have all the manuals on the CNC and Handy file but I cannot figure out how to get .txt format setup. It uploads just fine, any help would be great ! |
| Try this to output the current program: Press the [PUNCH] soft key. Press the ["FILE NAME] soft key Key in TESTPROG.TXT Press the [FILE NAME"] soft key Press the [THIS PROGRAM] soft key Or, to output O1234 as O1234.TXT Press the [PUNCH] soft key. Press the ["FILE NAME] soft key Key in O1234.TXT Press the [FILE NAME"] soft key Press the [PROGRAM#] soft key Key in 1234 Press the [EXEC] soft key Let us know... |
| Thanks dcoupar, I did exactly what you said and that did work, however , even though it did store it as .txt the file looks the same as before like a .dat file when opened. When i tried to copy and past it here, it was correct. It has those little squares, which is the begining of each new line. The program looks like a giant paragraph. Ha Ha The CNC settings must be wrong somewhere, I guess, Ha Ha ! I'm all ears ! OH ! and dcoupar nice pic !! Thanks |
| Par 0002 bit 2 and par 0000 bit 3 control the EOB characters when outputting. LF (par 0002 bit 2 = 0 and par 0000 bit 3 = 1) LF CR CR (par 0002 bit 2 = 0 and par 0000 bit 3 = 0) CR LF (par 0002 bit 2 = 1) See what yours is set for. What are you using for an editor to open the file? |
| Thanks dcoupar !! I will check those parameters ! Also this PC we're using has MS Word on it BUT it's only working in safe mode. I was using notepad and just tried Word and found this problem, didn't know Word was down. So i tried opening it on another PC with a working copy of Word and it opened correctly. I will reset the parameters you mentioned and update you on this today. THANKS !!!! |
| That Fixed IT !!! THANKS !! EIA 0000 #4 = 0 = ISO NCR 0000 #3 = 1 = punch LF CRF 0002 #2 = 1 = pnuch CR LF ( changed this one to 1 ) As long as we punch out programs with the .TXT it opens in NOTEPAD correctly !! Thanks a Million dcoupar |
| CNI floppy format | oldnapalm | Commercial CNC Wood Routers | 25 | 12-29-2008 02:50 AM |
| Problem- dxf format | blackrat | Rams Software | 0 | 02-25-2008 12:07 PM |
| floppy drives | dertsap | General Electronics Discussion | 2 | 04-30-2007 09:04 AM |
| Format 1 | MegaMoog | Fadal | 6 | 04-06-2006 06:08 PM |
| Using CRC in Format 2 | Mese | Fadal | 10 | 03-28-2006 07:37 PM |
