Old 12-18-2009, 02:04 PM
revis2son is on a distinguished road
21-t controller on dainichi lathe
I now have a turret servo alarm. How can i get this reset in order to home the machine?
Old 12-18-2009, 02:11 PM
dcoupar's Avatar
Has the machine been run recently? It may be you need to override the soft limits in order to zero out the slides. I believe if you power down then hold the P and CAN keys while the control powers up, it should allow you to zero out the machine.
Old 12-18-2009, 02:35 PM
This is the first time i have touched this machine. I do not know what they have used this machine for or who has used it. I believe that the turret was used to press some parts straight. They want me to get it up and running. thanks for your help.
Old 12-21-2009, 07:21 AM
hrh hrh is offline
hrh is on a distinguished road
Please elaborate on the turret servo alarm.
(Alarm displayed on screen and alarms on turret servo controller)
Maybe the backup battery for the absolute encoder has to be replaced and the reference procedure for the turret should be executed.
Check parameter 1815.
Need Help!- Parameters for Dainichi Lathe F35 dbstream Fanuc 2 10-14-2009 01:46 AM
Dainichi B45 lathe tmdmach Fanuc 2 10-08-2009 02:56 PM
Dainichi Lathe Fanuce 0T Jedi Fanuc 13 04-20-2009 05:22 PM
Dainichi F15 CNC lathe with Fanuc OT F.Sharifi Fanuc 0 07-07-2007 04:40 AM
Dainichi CNC lathe F16 Machine parametre F.Sharifi Fanuc 0 03-12-2007 04:49 PM
