Old 12-16-2009, 11:45 PM
kylef1978 is on a distinguished road
Fanuc 6MB Alarm 2
Okay so i fixed my +24 OV (alarm 8) on my Spindle Unit A06B-6044-H009 by switching the input wires R2 with S2 to lower the voltage on the driver board. now when i go to orient or turn the spindle on i am getting the LED 2 to light up. What causes the speed to deviate from commanded speed?
thanks
Old 12-17-2009, 08:48 PM
alexfanuc is on a distinguished road
ALM2
Check if the motor has a problem, Megg it. Can you turn it by hand easily?
Also, check the apindle unit. A bad transistor module could be the problem.
Sensor in the motor could also be the problem.
But, I´m wondering, what was the first alarm that you had, 8? Was the motor running alright?
Alexfanuc
Fanuc Alarm 440 jlwright Fanuc 6 03-14-2009 12:10 PM
alarm 408 servo alarm "serial not RDY", αP18 fanuc mtor code sting Fanuc 0 01-01-2008 09:03 AM
Fanuc O-M alarm 087 noltbros Fanuc 8 10-17-2007 06:40 AM
Alarm 421 on Fanuc 6M vfsi Fanuc 2 05-12-2006 10:44 AM
Alarm 972 on Fanuc 18-T steve-o Fanuc 2 04-07-2006 05:20 AM
