Old 03-30-2005, 09:17 PM
Jswenson2 is on a distinguished road
Question FANUC "EZ Guide"
Hello
I currently am using Fanuc 21i-tb with a Daewoo 240L Lathe. I want to install EZ Guide. My understanding is that the controller already has the program but it must be unlocked. I have seen this done before but I never figured it out. I want to learn this proceedure because it would be very useful in my situation.
Old 03-30-2005, 10:58 PM
Moderator
machintek is on a distinguished road
If during the boot up of the control, you see that ezguide is loading, then you are correct. It is in there. Also if you press the CUSTOM key, you should see the ezguide page flashing. This also confirms that it is loaded.
There are parameters that need to be changed to get it to work. I cannot tell you how as we are a dealer and this is an option.
George
Old 09-08-2008, 10:02 PM
fanucaholic's Avatar
*Registered*
fanucaholic is on a distinguished road
George
i work for a dealer also, and for versions of software before DEK1-15 it was pretty staight forward to turn on. this all goes to the arrogant stance of fanuc, not GE fanuc.
The dallas office of fanuc will waste my companys time now( and this policy has changed this year) to tell us that they have to send service before they will send the obvious part to fix customers machine under fanuc warranty. i have had this happen several times in last year, i tell customer need this from fanuc under warranty and then have to go explain why they have to wait for fanuc rep to come in and agree with me. fanuc should watch out, large companys may get fed-up and go to seimens,etc...
thanks
Old 03-21-2010, 04:33 PM
mroy0404 is on a distinguished road
Hello Fanucaholic
Could you please take alook at this link an verify if EZ guide is installed properly on this machine.
Manual Guide i problems
Thanks so much for your time
Mike
Fanuc 3M DNC operation max_c General Metal Working Machines 3 07-04-2010 08:11 PM
FANUC "EZ Guide" Jswenson2 CNCzone Club House 0 03-30-2005 09:53 PM
Fanuc motor ??? jevs Servo Motors and Drives 3 03-16-2005 05:47 PM
FANUC coding compatability?? m1911bldr TurboCNC 3 04-24-2004 06:10 PM
