Old 12-10-2009, 08:03 AM
John_B is on a distinguished road
Multiplier and counter setting for 0m-C 4th axis??
Can anyone advise how to determine the appropriate parameter settings for a 4th axis on a Fanuc 0m-C? The machine formerly had a 4th axis, but I don't have that unit and don't know what reduction it had.
What I am trying to do is set up the machine to use my Tsudakoma 4th axis and my 5c indexer depending on the work I am doing. They both have 5 series motors with 2000 PPR encoders. I have them both working and wired identical, but they have different gear reduction ratios, so I need to figure the parameter settings for each. One has a 120/1 reduction and the other a 180/1.
I have the 68335 Maintenance Manual and have found the list of parameters related to the 4th axis, but can't seem to sort out the ratio aspect. All else it good.
Regards,
John
Old 12-11-2009, 12:07 PM
guhl's Avatar
guhl is on a distinguished road
I think you should use CMR and DMR.
See PDF
If you need I can send you the total manual
Soviet ICs are the largest ICs in the world!!! )))
Z Axis Counter Balance JerryFlyGuy Mechanical Calculations/Engineering Design 59 12-22-2011 09:58 AM
setting counter to count more than one CNC-Hammer Okuma 18 07-22-2009 05:43 AM
Z axis counter acting up! Fighter Tree 0 11-11-2007 09:04 PM
counter balance for z-axis paul_m_hutton DIY-CNC Router Table Machines 21 11-19-2006 11:17 PM
Z Axis Counter Balance??? bio_eng DIY-CNC Router Table Machines 6 12-05-2003 01:13 PM
