As long as you have a serial port on your machine and a cable to connect to your pc. You can use windows hyperterminal to send. Just start a new connection in hyperterminal and make sure all the info matches up to what is on your machine. |
Software Hand Shake DB25(PIN) DB-9 (PIN) SD (PIN#2) SD( PIN#3) RD (PIN#3) RD (PIN#2) SG (PIN#7) SG (PIN#5) JUMP (PIN #4 &5) JUMP (PIN #7 & 8) JUMP (PIN # 6,8 &20) JUMP (PIN # 1,4 &6) +++++++++++++++++++++++++++++++++++++++++ Control Side Settings: PUNCH CODE = 1 (0:EIA 1:ISO) I/O CHANNEL = 0 (JD5A CONNECTOR,CHANNEL 0) PARAMETERS 0000 = XXXXXX10 0100 = 00000000 0101 = 10000001 0102 = 0 0103 = 10 |
Just go to radio shack and get the 9-25 pin cable, and a null modem adapter. Saves trying to make a cable if your not good at it. The parameter settings listed will work, but he didn't give the actual baud rade, parity, stop bits with it. I don't have a manual at my desk to look it up. BTW an i series can use a ATA flash card or compact flash card with an adapter. Much easier than RS232. |
| yes that is true i have one and it works.. much easier to buy it.. you are going to need a null modem adapter the 9-25 pin adapter and a gender changer.. . |
I/O CHANNEL = 0 and Parameter 20 =0 means same thing.........so your parameter 20 will set itself as long as u put 0 on I/O CHANNEL. parameter 101 sets teh following values: #7 (NFD) 0 : Feed is output when data is output. 1 : Feed is not output when data is output. #3 (ASI) 0 : EIA or ISO code is used for input/output data. 1 : ASCII code is used. #0 (SB2) 0 : No. of stop bits is 1. 1 : No. of stop bits is 2. I totally agree PCMCIA Adapter with compact flash hard is the best way to go if you don't have dataserver option. I/O CHANNEL = 4 = Parameter 20. Parameter: 0103 Baud Rate 1: 50 5: 200 9: 2400 2: 100 6: 300 10: 4800 3: 110 7: 600 11: 9600 4: 150 8: 1200 12: 19200 [BPS] |
