I have the description manual for that board (B-90699E/03) and have the board too, but have no actual experience using that. It can be used on the 5,6,7,9,11,12,200A/B,3000C and 2000C controls.
Does anyone know what this board is..?
A16B-1200-0270
I bought a machine with Fanuc 6MB11 a couple of years ago and this board was attached inside the cabinet door but not connected in any way..
I'm told it is a buffer board for drip feeding..?
If it is I would like to connect it!
cnc-it
REMOTE BUFFER FOR OLD NC
You do need to setup parameters to run your DNC. This board has jumpers which need to be set
correctly.
Remote Buffer:
INPUT DEVICE 1 = 1
INPUT DEVICE 2 = 0
FOR REMOTE BUFFER, you need to set communication parameters by using jumpers on the REMOTE BUFFER PCB.
You need the manual : B-90699E/03 which has details about jumpers.
Thanks Guys I'll try and get the manual as there are no cables with mine so I will have to make some.
I presume then that this is a Fanuc version of a BTR and replaces the tape reader..?
Hi have managed to get The Fanuc remote buffer descriptions manual B-90699E/03 . It doesn't detail how to connect the board to the Fanuc 6 motherboard. It looks like I run the tape reader ribbon cable that already goes into the motherboard from the remote buffer then connect the tape reader to the remote buffer? Just need to make sure on this before I try anything!
John.
i want anstall a board remort bufer A16B-1200-0270 ,but i dont hav manual B-90699E/03
if you hav send me by email : lmostafa@hotmail.fr
thaks
best regards
John,
Did you ever get the A16B-1200-0270 remote buffer working? I'm looking to put one on my Fanuc 6M ?
I see you sourced the manual for it - was it in electronic format - if so can I be cheeky and ask for a copy to andrew@mawson.org.uk
I've tried pming you but your inbox is full!
Many thanks
Andrew
Andrew Mawson
East Sussex, UK
Do you have the manual in PDF ?
sgarciam2@yahoo.com
Thnak You
THIS PCB IS A TAPE READER EMULATOR WITH
YOU HAVE TO CONNECT IT ON THE HE50 CONNECTOR OF THE TAPE READER
SELECT RMT IN THE SETTING SCREEN
YOU SEND BY RS232 YOUR PROGRAM AND THE COMMUNICATION SHALL STOP AT SOMETHING LIKE 4MB (BUFFER FULL )
THEN CYCLE START
Can you share me these documemt to my mail: dien08td@gmail.com
Dear friend.
Can you share me " B-90699E/03 " file???
My mail: dien08td@gmail.com.
does any one have a copy of the manual please B-90699E if so can they email me it service@skippysmt.com
