Old 11-23-2009, 02:48 AM
MysticMonkey's Avatar
MysticMonkey is on a distinguished road
Fanuc Eprom
Does any one have any information about
fanuc eprom types and exchangeable eeprom types ?
*~~Darwinian Man, though well-behaved, At best is only a monkey shaved!~~*
*__________If you feel inclined to pay for the support you receive__________*
*_______Please give to charity http://www.oxfam.org/en/getinvolved_______*
Old 11-23-2009, 03:01 AM
tranhaitrung is on a distinguished road
chinese? I don't know chinese!
Old 11-23-2009, 05:42 AM
M.RISHIKESH is on a distinguished road
Fanuc EPROMS
In case of Fanuc OM, PMC M board will have 2 EPROMs (OF1 and OF2 27C256)
Old 11-23-2009, 09:14 AM
Graham Young is on a distinguished road
We have eprom sets to upgrade Fanuc 03 adn 6 controls to have serial port Drip feeding for DNC. Different controls use differetn Eproms. Dpends what it is Fanuc 0A, B and C can use differnt types. Some fanuc 3 controls use different Eproms and have a switch for the diferent types others do not. YOu need to check the chip type. YOU can get them from different manufacturers as long as they are the right type. Fnauc 6MBII can use any 2764 eprom
Graham Young
Memex.ca
Old 11-23-2009, 12:47 PM
C1KEENAN is on a distinguished road
USUALY THE BEST ADVICE ON THE OLDER FANUC CHIPS IS READ THE LABLE OF THE ORIGINAL AND GET ONE THAT HAS THE SAME NUMBER, THE SPEED IS NOT AS IMPORTANT, BUT SOME OF THE OLDER CHIPS ARE PROGRAMED AT A DIFFERENT VOLTAGE. YOU CAN BURN UP SOME PROGRAMERS IF THE WRONG VOLTAGE CHIPS ARE USED
Old 11-24-2009, 03:26 AM
Bones75 is on a distinguished road
Been down that road..
I have been thru the headach and months of research, mostly the search.
If give the specific type of Fanuc your dealing with, as well as what your trying to acompolish, we might be able to help more.
I personally have a Fanuc 3M, which we basically had to reverse engineer, and finally get the correct ladder/logic info in it.
For a fanuc that old, if your having issues, its more then just the E-proms on the motherboard, which are the ones that get changed out if your trying to upgrade to a drip feed for that paticular controller.
But also, on the Fanuc 3, the PC1 card contains the machine ladder logic, and without a specific match for the machine, you got a lot of work tracking it down.
Drop me a line, if it is a Fanuc 3 your dealing with, I might be able to help you out. Just rememebr, need the specific controller, "Fanuc ?what?", and the numbers on the motherboard will also help. I have several different fanuc manuals, which may have info you need.
Need Help!- To burn EPROMs for Fanuc 0T on std EPROM programmer gautam1806 Fanuc 0 10-09-2009 01:14 AM
Newbie- Help cross referencing Eprom chips nlh General Electronics Discussion 5 06-11-2009 11:34 AM
Fanuc Eprom gabedrummin Fanuc 5 06-06-2009 04:26 AM
Techno MAC100A Eprom shenlung General CNC (Mill and Lathe) Control Software (NC) 0 06-27-2007 12:40 PM
EPROM (?) info brgrii General CNC (Mill and Lathe) Control Software (NC) 2 10-05-2006 03:34 PM
