Old 11-21-2009, 05:56 PM
jlpd is on a distinguished road
SOS / help : fanuc 15T system with "OT007 z+ overtravel (Hard) alarm" FORCE sIGNaL
Good Day Frieds & Expert.
appreciate all help & advice. I have problem with fanuc 15T system with "OT007 z+ overtravel (Hard) alarm" and cannot be RESET.
Did check all wire and overtravel switch working find. Did manually force the switch and check at PCDIagnosis bit did change 1 to 0 (on & off) X39.2 DI.
It somethin like "internal force signal" which cause this issue. It's related to Parameter seeting?? Which parameter it's & how to resolve this problem.
DID TRY "caN + P" aLSO NOT WORKING.
anybody knOW how to internally disable / reset this alarm.
is there any link to between Parameter 1000, Parameter 1005 & Parameter 1815.
What is the correct setting for those Parameter?
I really need urgently support since this Danichi 152 was sleep almost 3month.
anybody can help much more appreciate.
thx
Old 11-22-2009, 10:22 PM
MysticMonkey's Avatar
MysticMonkey is on a distinguished road
Faulty Z+ Hardware. Over travel switch, wiring or I/O
*~~Darwinian Man, though well-behaved, At best is only a monkey shaved!~~*
*__________If you feel inclined to pay for the support you receive__________*
*_______Please give to charity http://www.oxfam.org/en/getinvolved_______*
Old 09-04-2011, 02:08 PM
yours_prabhat is on a distinguished road
OT 007 +OVERTRAVEL (HARD)
DEAR FRIEND ,
PLEASE CHECK THE LIMIT SWITCH OF THE OTHER END [OT 007 +OVERTRAVEL (HARD) THE STROKE LIMIT SWITCH LOCATED AT THE POSITIVE SIDE WAS TURNED ON].I MEAN + SIDE OF AXIS, Also cable and 24 v supply on other side Limit sw.
HOPE YOU CAN RUN THE MACHINE NOW.
REGARDS
PRABHAT MISHRA
prabhatmishra@gmx.com
Old 09-04-2011, 02:18 PM
Al_The_Man's Avatar
PRABHAT MISHRA
Yeah, hopefully after 2 years!!.
Old 09-04-2011, 02:25 PM
Al the man,
I posted this message for update review not for JlpD so please do not mind as you are so intelligent so better to talk in a technical way.
Regards and honor to your presence and interactivity
Prabhat
Newbie- Need CNC machine to cut .01" 302 full hard SS sheets (6" x 20") Lowe Want To Buy...Need help! 0 03-23-2009 12:58 PM
Need Help!- Fanuc system 9 loading "hang" waterfall General CNC (Mill and Lathe) Control Software (NC) 0 11-15-2008 08:35 PM
alarm 408 servo alarm "serial not RDY", αP18 fanuc mtor code sting Fanuc 0 01-01-2008 09:03 AM
Fanuc O-MC Alarm 405 "Z axis wrong (ZRN)" JSaindon Fanuc 2 09-19-2007 10:22 AM
Fanuc 18t Turret alarm "1110" senna95 Fanuc 0 10-18-2006 11:03 AM
