Old 11-21-2009, 01:33 AM
fomaz is on a distinguished road
Change maximum motor speed
I am working (rebuilding) on a lathe with fanuc 21-TB with alpha series motors. My experience with fanuc is limited, and resumes to work on a vertical machining center with fanuc 21i-M.
On the VMC, that I also rebuilded, I remember that in parameters there was some parameters that had the maximum axes speed or similar that in that case was 42000 (mm/min).
In this "new" machine I do not have such a parameter and I have no ideia how to tune the motors. I have the parameters manual, but it is not clear to me. I do know that in the machine maker manual says that axis max speed is 12000 mm/min and machine is for sure below this speed. Thank you for any information.
Maximum spindle speed for HF 8x12? saltytri Mini Lathe 3 09-21-2009 11:51 PM
Maximum speed fbazan Yeager Automation 0 09-13-2006 09:30 PM
New Taig, 8 ipm maximum rapid speed? fivaxis Taig Mills & Lathes 5 05-11-2006 08:55 AM
What is the maximum practical speed you could run a stepper at? phantomcow2 Stepper Motors and Drives 6 03-15-2006 08:15 PM
Does controller change axis motor speed? samualt DIY-CNC Router Table Machines 5 10-10-2003 04:05 PM
