#13
| All the info I have show a different main board number for the 10 also you should have a large 7 segment diagnostic display digit on the main board that displays 0-F, which the 0 does not have. I would confirm for sure what you have before you order manuals etc. also the Keyboard/CRT unit usually has the Fanuc series number on it. Al.
#15
Al
#17
| Does anybody have any Series 0 technical information they can fax me?!? My favorite lathe is down yet again and again for a different problem. It was running fine Friday but wouldn't start today. I am in the blind with this machine with little to no referencing information. The spindle will not come on in midi or when executed through thru program. The "?" lights up when the spindle is supposed to come on. |
#18
| I may be able to send you something later this PM as I am not at the location right now, I have to pick the CD up. Al.
#20
| It is acting like the machine does not know if the chuck is open or closed. I don't have any technical referencing information to see if there is a switch there and if it is made. The machine is a Takisawa TC-2 Lathe Machine, any ideas. |
#21
| The Fanuc data I have will not be much use in this instance as your problem is machine specific rather than a control problem, per se. You need the Takisawa Electrical control manual. I assume it is either a pneumatic or hydraulic operated chuck, have you already looked for pressure/limit switches that could register the chuck status? Al.
| What is the Difference between 6000 series aluminium and 7000 series | Kosta1234 | General Material Machining Solutions | 3 | 11-19-2005 08:04 AM |
| OneCNC XR Series Profile CAD/CAM Released | OneCNC | Product Announcements & Manufacturer News | 0 | 03-07-2005 04:32 PM |
| EX 02 Safety Limit Switch Engaged FANUC 11 SERIES ON NTC MACHINE | Epik | General CNC (Mill and Lathe) Control Software (NC) | 0 | 02-27-2005 04:20 PM |
| Series Bipolar and parrallel bipolar? | CNCadmin | FAQ of CNC Machine building | 0 | 09-08-2004 07:17 AM |
