Old 11-17-2009, 11:18 PM
amurphysmu is on a distinguished road
Fanuc OM DNC Parameter
Just got a cheap machining center with an 0MC control but have no manuals and have never operated fanuc controls. I'm trying to change the parameters per: http://www.aggsoft.com/cnc-dnc/fanuc-0m.htm to enable DNC.
But my machine won't let me.
For example:
I set PWE to 1 in DGNOS PARAM while in MDI mode
Navigate parameter 552, type 9, then INPUT, but nothing happens.
What am I doing wrong?
Old 11-18-2009, 02:27 AM
MysticMonkey's Avatar
MysticMonkey is on a distinguished road
Not sure If your control or the 0 C supports it but try a
G10 L50;
N552 R9;
G11;
in MDI
*~~Darwinian Man, though well-behaved, At best is only a monkey shaved!~~*
*__________If you feel inclined to pay for the support you receive__________*
*_______Please give to charity http://www.oxfam.org/en/getinvolved_______*
Old 11-18-2009, 03:59 AM
f-bu is on a distinguished road
If there is a separate key switch on the operator's panel, turn it to disable and try again.
Old 11-18-2009, 09:00 AM
James L is on a distinguished road
Setting 55
On my machine DNC is enabled through the settings on number 55. Has an option for either 'ON' or 'OFF.' Some controls might have it set to be either '0' or '1.' That was all that was required to turn it on. Hitting the MDI button twice would put my control in receive mode. I use hyperterminal to send and receive.
Old 11-18-2009, 10:38 AM
There is a tape switch on my machine. But it doesn't look like there is anything configured to set the baud rate, stopbits, databits, or parity.
Old 11-19-2009, 05:16 PM
John_B is on a distinguished road
My 1990 Tape Drill machine with the 0m-C has full DNC capability, which is initiated by pressing the Remote button on the operator panel next to Memory. My Kiwa machine is the same year and control, but slightly different software version (and ladder obviously) and doesn't at this time support it?? MTB thing I'm sure.
amurphysmu, send me a PM with your e-mail and I'll get you what I've got in documentation if it will help.
Fanuc o/t parameter help JimOtoole Fanuc 2 03-31-2009 09:38 AM
Need help with Fanuc 6MB parameter nguyenthanhthi Fanuc 0 07-23-2008 11:15 PM
Fanuc 6t parameter #0-5 and #300-304 ixoxi999 Fanuc 1 12-24-2007 07:44 PM
Fanuc 3m parameter salmve Fanuc 2 06-01-2007 11:11 AM
parameter fanuc om-d dlmusinage Fanuc 1 05-17-2006 04:54 PM
