Old 11-16-2009, 12:21 PM
ED209's Avatar
ED209 is on a distinguished road
Fanuc OM Alarm 087
Can anyone please explain what alarm 87 on a Fanuc OM means ?.
Alarm 087
When entering data in the memory by using Reader / Puncher interface, though the read terminate command is specified, input is not interrupted after 10 characters read.
Our programs look like the following;
O0010(ABC-123-ABC-A.123)
(ABC-123-ABC-A.123)
N10
N20
N30
M30
Old 11-16-2009, 12:34 PM
guhl's Avatar
guhl is on a distinguished road
Also manual says in alarm description "PCP or I/O unit defective
There is another explanation of alarm 087 in attached PDF page
If you need I can send you the total manual
Soviet ICs are the largest ICs in the world!!! )))
Old 11-16-2009, 12:56 PM
ED209's Avatar
Thanks, your version reads different from the manual we have.
Old 11-16-2009, 08:26 PM
dcoupar's Avatar
PS087 is Buffer Overflow. Your PC doesn't stop sending within the
allotted time (10 characters) of receiving the XOFF.
Check your Windows - Control Panel - System - Hardware - Device Manager - Ports - under Advanced there's FIFO Buffer settings. Slide them all the way to the left then uncheck "Use FIFO buffers".
OK all the way out and then restart your PC to have the changes take effect. See if that does the trick.
Old 11-16-2009, 09:58 PM
WGoyer is on a distinguished road
Alarm 87
I think your handshaking isn't working. Most people use software handshaking (Xon/Xoff) or also known as DC codes (DC1 through DC4). Handshaking is meant to stop the transfer until the control needs it.
Some people use hardware handshaking to accomplish the same thing. If your cable has just three wires, it most certainly is set up for Xon/Xoff.
Slowing down the baudrate on both ends can sometimes make enough difference so handshaking isn't needed, especially if you are just loading memory, not drip feeding.
Warren
www.uptimecorp.com
Old 11-17-2009, 12:15 AM
fanucman is on a distinguished road
check the io settings.. and baudrates with the computer you are trying to communicate with..
Iso=1
if
I/o channel is
0 check parameter 2 bit 0 and 552
1 check parameter 12 bit 0 and 553
probably a bad setting.. computer setting four stop bits and baud rate must match
Need Help!- Fanuc 424 alarm DALEK Fanuc 23 01-21-2009 11:27 AM
alarm 408 servo alarm "serial not RDY", αP18 fanuc mtor code sting Fanuc 0 01-01-2008 09:03 AM
Alarm 412 in fanuc 3M rajesh_1355 Fanuc 2 12-15-2007 09:58 AM
Fanuc 6M-B 078 alarm Rick Emerson Fanuc 0 12-01-2006 03:10 PM
Fanuc 6M alarm: 231 -Z OT. thanhct Fanuc 1 12-01-2006 05:31 AM
