I have a Ikegai With a fanuc 6T Control. DC spindle Drive No. A06B-6041-H106. The phase fuses blow upon a run command. I checked all of the SCR's for shorts but all seem ok. I measured the resistance on the motor armature and it reads about 2 tenths of an ohm, seems kinda low to me. I measured the resistance on another motor and it measured 7 tenths of an ohm. ![]() I would appreciate any help on this problem. Thanks, jerry |
| Do the fuses hang in if you disconnect the motor? Inspect the brushes and the commutator. Resistance reading will not tell you much. Al.
| Hi Al thanks for the quick reply I haven't tried turning it on with the motor disconnected. But the fuses don't blow until I tell the spindlw to go. I will check the brushes and comutator as you suggest. again thanks. Jerry |
| Also if you have access to a Megger it will detect grounds etc. Al.
| Need Help!- 6M Spindle Drive Error Phase Led | CMK1 | Fanuc | 4 | 04-13-2009 01:38 PM |
| Need Help!- Help...Before I blow another drive! | hcrotalus | Gecko Drives | 12 | 03-21-2009 09:49 AM |
| Need Help!- 1.3 amp alarm fuses blow on my Velocity Control Unit | gcpmachine101 | Mazak, Mitsubishi, Mazatrol | 6 | 09-26-2008 04:17 PM |
| Need Help!- 1.3 amp alarm fuses blow on my Velocity Control Unit | gcpmachine101 | Mass finishing equipment/media/stratigies | 2 | 09-26-2008 09:52 AM |
| 5 amp fast blow fuses | planescott | Gecko Drives | 2 | 02-21-2006 03:06 PM |
