| It could depend on a couple of things. If the machine builder has locked the ladder or not is a big one. If they have you would need their password. If not first thing is to make sure you make a backup of the original. After that you may have to go into the PMC side, PMCPRM and then settings and turn on the bits that allow for editing and writing to F-Rom. You should stop the ladder at this point. You should then be able to go into the ladder and use the onboard editing functions. Once you make your changes, start the ladder again and test to make sure the changes you made are what you want. When you are satisfied you will need to do a "Write to F-rom" to save the changes or else you will lose them and revert back to the previous ladder when you power down. Hope this helps some. JP |
| So, I guess, the ladder can be backed up on memory card through I/O soft key on PMC screen. When we mess up the original ladder, and want to restore the original one, what would be the procedure: READ from M-CARD, followed by WRITE to F-ROM? |
| go back to boot screen, select system data loading, then select the file, i forget what its called now.. list all file names you have under that screen and ill tell you which one it is.. i always load it in this way.. |
#10
by holding the the furthest left and furthest right most keys under the screen and powering up the control.. |
| Ladder editing | luca_r | Mazak, Mitsubishi, Mazatrol | 7 | 06-05-2009 03:02 AM |
| Need Help!- Ladder Editing on M32B | Jwl | Mazak, Mitsubishi, Mazatrol | 2 | 05-15-2009 09:02 AM |
| Need Help!- EDITING WITH FANUC LADDER III | CHAD LAWSON | Fanuc | 2 | 01-30-2009 06:36 AM |
| Ladder on 0T | guhl | Fanuc | 4 | 08-17-2008 10:15 PM |
| Fanuc ladder editing card | bob1371 | Fanuc | 1 | 04-10-2006 10:50 AM |
