Old 11-08-2009, 02:04 PM
Daniel Boone is on a distinguished road
PROGRAM CHECK FANUC O-T
I have a lathe with a Fanuc O-T, everytime I try to run this program it always stops at the second line of G71 and gives a error for an illegal command. I am fairly new at CNC I am sure that it is something simple that I am missing.
File Type: txt PULLEY GROOVE OD.txt‎ (700 Bytes, 43 views)
Old 11-08-2009, 02:51 PM
timlkallam is on a distinguished road
you have g72 not g71
I don't think it will work a g71 toolpath should be a path thats asending or desending not moving downt then back up .
be carefull cut air first.
Tim
Old 11-08-2009, 02:54 PM
I have tried changing it to g71 also and it still does it. this program is for cutting two .570 deep tapered grooves that is why I did it as g72.
Old 11-08-2009, 03:13 PM
The g72 cycle is stock removel in facing.
Tim
Old 11-08-2009, 04:31 PM
Is there any way to write this through the grooving cycle and using the chanfer option?
Old 11-08-2009, 06:35 PM
Dan I don't think there a caned cycle that will cut a pully grove I could be wrong g75 maybe . I think you might have to just write it longhand.
Here is a link to g71 programing by Peter Smid
http://books.google.com/books?id=JNn...age&q=&f=false
Tim
Old 11-08-2009, 10:28 PM
sinha_nsit is on a distinguished road
Replace R0500 by R0.05, as it is in inches.
G71 Type II can have non-monotonic increase/decrease in diameter as you move along the axis, but, while defining the profile, you cannot have two X-values at the same Z-value.
G72 also has similar restrictions.
So, plot the defined profile to check if it is permitted.
Need Help!- fanuc 10m Io030 check sum error skippyfix Fanuc 1 07-02-2009 06:52 AM
Check Program Exists guypb Mazak, Mitsubishi, Mazatrol 8 02-20-2008 02:24 PM
Program Check guypb Haas Mills 0 02-14-2008 12:39 PM
program stop to check size jone Mastercam 2 05-23-2007 09:19 PM
Check toolpath on program and it only shows a jog square carbidecraters Fadal 2 06-15-2006 08:40 AM
