Old 11-05-2009, 10:42 PM
rbcmetalwork is on a distinguished road
Parameter Backup on 0i Mate-MB
I'm preparing to change the 3V battery on the control unit. Before I do that I'd like to backup the parameters and anything else that could be lost. What is the procedure for backing up the machine parameters? I have RS232 communication established with a PC if that helps.
Randy
SV-2412, 0i Mate-MB
Old 11-06-2009, 12:46 AM
fanucman is on a distinguished road
do a SRAM backup.. get a compact flash card from sandisk and a pcmcia card adapter (less than 2 gb).. stick the card in the memory card slot
hold down the 2 outter softkeys under the screen and power up the control..
go to sram data back (sram data utility)up via the soft keys.. and select backup..
This is the best way to backup the machine...
now if you want to do it via rs232
punch out the parameters, pmc parameters, pitch errors (if available) macros, programs (make sure 3202 is set to output 9000 programs), offsets
Old 11-09-2009, 08:04 PM
I got a PCMCIA card adpater with a 512MB compact flash card as you suggested. After holding the two soft keys and powering up, I can't find the SRAM data utility. I currently have the control configured for RS232 communications. Do I need to change any parameters to be able to write to the PCMCIA card?
Randy
SV-2412, 0i Mate-MB
Old 11-09-2009, 11:35 PM
no it should say... SRAM DATA BACKUP OR SRAM DATA UTILITY..
you dont need to change any parameters.. it has to work it might just be worded differently
Old 11-10-2009, 01:31 PM
I tried the two softkey control power up again. No joy. I don't see anything to do with SRAM. I know that the PCMCIA card works as I punched the parameter information to it. I did have to change the I/O channel to 4.
Randy
SV-2412, 0i Mate-MB
Old 11-12-2009, 03:45 PM
MysticMonkey's Avatar
MysticMonkey is on a distinguished road
There are three methods for accessing the Fanuc Boot screen
1 hold the two soft keys on the furthest right " - > "
Options 2 and 3 depend on the size of your screen
2. hold the two arrow soft keys (Small screen)
3. Hold the Right arrow soft key, and 7th from the right (large screen)
Options 2 & 3 allow you to backup the Fanuc NC software (not normally necessary as this is not stored on volatile memory.
Turn on the NC while holding these keys
you will see the black boot screen
use the soft keys to navigate the menus
SRAM BACKUP
end quits out of the current menu
*~~Darwinian Man, though well-behaved, At best is only a monkey shaved!~~*
*__________If you feel inclined to pay for the support you receive__________*
*_______Please give to charity http://www.oxfam.org/en/getinvolved_______*
Old 11-12-2009, 04:30 PM
SRAM BACKUP
thanks, your absolutely right.. all oi's only have 6 buttons below the screen so you need to press the furthest right and left for boot screen..
Old 11-13-2009, 12:19 AM
Okay, I get it now...
I didn't comprehend that you had to hold down the soft keys until the boot screen comes up. I was holding them down, pressing the control power on button and then releasing them.
Thanks guys for all your help. All is backed up now.
Randy
SV-2412, 0i Mate-MB
Old 01-16-2010, 04:24 PM
saul is on a distinguished road
were can i find
were can i find the files of the rom my control rom is empty and need the files were can i find that after a initialization of rom
chevalier 1418vmc-40 0i mate mc
Old 01-19-2010, 12:16 PM
fanuc-support.c's Avatar
fanuc-support.c is on a distinguished road
Why did you inialize the F-ROM? Not a good idea with out a back up.
A good MTB will leave a disk in the electrical cabinate, look there.
The majority of the time Fanuc can replace it all for you, System software, macro lib, servo software, all standard.
But if the machine tool builder has custom files on there (fanuc picture - macro executor - datau) then you need to go to them.
Having worked at Fanuc for many years, i know how poor MTB's are keeping copies of machine files safe.
Good luck.
The Fanuc Support Center Team
www.fanuc-support.com
  #11   Ban this user!
Old 01-29-2010, 03:25 PM
mroy0404 is on a distinguished road
Hope this will help you.
  #12   Ban this user!
Old 01-29-2010, 11:42 PM
YouTube- Fanuc 16i/ 18i/ 21i SRAM Memory backup
SRAM backup does not conatin the Ladder you must do that separately
Meldas 64M Backup Hypnotique Mazak, Mitsubishi, Mazatrol 1 02-13-2009 10:24 AM
Backup Fanuc Tape Drill Mate Model T. GPena Fanuc 0 11-14-2008 11:42 AM
Mazak Fusion Parameter Backup Mark18969 Mazak, Mitsubishi, Mazatrol 1 01-07-2008 10:42 AM
Do you use SEND ALL for backup? gar Haas Mills 7 06-28-2007 08:19 AM
Backup Script.. Rekd Mastercam 3 09-11-2003 09:34 AM
