Old 11-05-2009, 11:07 AM
rbcmetalwork is on a distinguished road
PC to Fanuc File Transfer
I'm trying to transfer my NC program from GibbsCAM to the 0i Mate-MB control. I have a null modem cable and have set the parameters on the control and the PC as listed on this webpage I found.
http://kfasllc.com/rs232_0.htm
I've read the Fanuc manual several times and nowhere can I find any procedure for file transfer via RS232. I feel like the manuals are full of information which I can't/won't use; like trying to find the 6V battery which doesn't exist.
Can anyone tell me the proper procedure (what buttons to press) to prepare the control to receive the file? I think I need to be in EDIT mode and then hit the PROG key but I get lost after that.
Randy
SV-2412, 0i Mate-MB
Old 11-05-2009, 03:59 PM
fanucman is on a distinguished road
it doesnt work because you are using parameters for a 0 control not a Oi.
go to offset setting button..
make i/o =0
tv check off
punch code=1 (for ISO)
make pwe 1
go to system, parameters
make 101 10000001
103 10 for 4800 baud
11 for 9600 baud
Old 11-05-2009, 10:18 PM
File Transfer Successful
fanucman,
Thanks for the parameter information. The file transfer work fine now. I did have to change to a straight through serial cable though. The null modem cable would not work properly.
Randy
SV-2412, 0i Mate-MB
Old 11-06-2009, 12:55 AM
Originally Posted by rbcmetalwork View Post
fanucman,
you will need a null modem adapter.. a strait through cable WILL NOT WORK with out one..
call fanuc they can send you a pin out if you want to make your own..
Old 11-06-2009, 11:19 AM
By straight through cable, I meant that I made a cable with the pinouts as shown in the attached picture (DB25 to DB9). With this cable I successfully transferred a few programs which ran fine with no problems. Am I missing something? I'd hate to screw something up.
Randy
SV-2412, 0i Mate-MB
Old 11-06-2009, 12:45 PM
i thought you meant straight through w/o pins jumped...
Old 11-18-2009, 08:50 PM
sudhirudar is on a distinguished road
I have a .pdf for all the controls with cable digram and RS232 STEP BY STEP procedure to connect a pc to cnc or vice versa.
write to me at sudhirudar@yahoo.com
PC to Fanuc File Transfer rbcmetalwork Sharp CNC 0 11-05-2009 01:32 AM
fanuc control rename sub routines on file transfer? yrdnalffej Fanuc 4 10-18-2009 03:56 PM
Parameters No. for file transfer on a Fanuc O-mate controller Niall Fanuc 8 06-03-2009 08:14 AM
file transfer axis overtravel Fadal 13 01-26-2006 09:55 PM
EIA file transfer grunemh Mazak, Mitsubishi, Mazatrol 0 12-02-2005 07:45 AM
