Are the offset distances on a lathe always radial values even if we are using diameter programming? In other words, if we increase the wear offset by 0.01, will the machined diameter increase by 0.01 or 0.02? |
| It would seem to me that if you program in dia. the offsets should be the same. I think the machine can be set to either depending on your preference. Although dia. should allow finer resolution. As .0001" rad. is .0002" dia.. We had a Robodrill installed that was set to rad. for tool dia offsets.....Silly giving up the finer resolution. A simple parameter change later and better parts As before mentioned a test part will tell you what you are dealing with. And if it is rad. I would call your dealer or the man. and find the parameter to change to dia. |
| You are right. I checked on 0i Mate TC (I started this thread because I wanted to save my time!). My machine (rear-type lathe) uses diameter programming. So, all offset distances are diameter values. Moreover, when I specify a negative wear offset (which was initially 0), it pulls the tool towards the spindle axis by the specified amount, without changing the coordinate display. This means that a smaller diameter would be obtained for the same program. So, to compensate for tool wear (which gives larger OD than the programmed value), a negative wear offset value should be specified, in case of OD machining on a rear-type lathe. Am I right? |
| measuring a diameter by x & y point values | Doug Tyler | Calibration & Measurement | 1 | 01-04-2008 05:18 PM |
| Changing Radius To I And J Values | macca_loto | Mastercam | 12 | 10-01-2007 11:23 PM |
| Offset values get changed | sab | General Metal Working Machines | 0 | 06-27-2007 11:42 PM |
| wire offset values | Stevatome | Fanuc | 4 | 03-09-2007 07:42 AM |
| Lathe Dainichi F35 Fanuc 18TA - change diameter on radius | jutek | Fanuc | 1 | 02-21-2007 03:57 PM |
