Old 10-30-2009, 11:50 AM
POOR ENGLISH is on a distinguished road
HELP FOR OPTIMISE TOOL CHANGE
NEED HELP!
WE HAVE A VERTICAL TURNING CENTER TOSHIBA TUE-20
WITH A FANUC SERIE 18T CONTROL
EACH TIME WE MADE A TOOL CHANGE THE MACHINE MOVE TO THE REF.POINT
AND AFTER SHE MOVE IN Z AND X EQUAL TO THE VALUE OF THE OFFSET OF THE TOOL.
I WANT TO KNOW IF IT'S POSSIBLE TO REMOVE THIS 2 MOVES THAT TAKE TIME AND WEAR THE SLIDE UNNESSARY.
THIS IS THE PROGRAM FOR TOOL CHANGE;
:9021(ATC)
G04X0-----I DON'T KNOW WHY?
M05
G28W0-----THIS IS HERE THE MACHINE MOVE EQUAL TO Z OFFSET
G28U0------THIS IS HERE THE MACHINE MOVE EQUAL TO X OFFSET
IF[#1005EQ1]GOTO100
IF[#4006EQ20]GOTO10
#25=1
GOTO20
N10#25=25.4
N20M06
G98
G00W[-246.680/#25]M64
G04P1000
G00U[800.400/#25]
G01W[-7.0/#25]F[2000/#25]
M67
G04P1000
G00W[190/#25]
M63
W[-175.0/#25]
G01W[-15.0/#25]F[1000/#25]
M66
G01W[7.0/#25]F[2000/#25]
G28U0
G28W0M65
G99F[0.1/#25]
N100M99
THANK
Old 10-31-2009, 11:25 AM
John_B is on a distinguished road
The G04 X line is added sometimes to dwell for a short time when using slower controls that need register ready signals. With the X value being 0 there is no dwell so it is not slowing anything down. I would just leave that alone.
The G28W0 and G28U0 lines are probably in place to move to a safe place prior to changing tools so there is no crash. These can be made into comments so they will be ignored by simply place brackets around them: (G28W0) and (G28U0). This way the control will skip them, but you can leave them in in case you want to use it in the future to avoid chuck fixturing or something else.
Old 11-04-2009, 05:44 PM
dpuch is on a distinguished road
G28W0 and G28U0 you marked are before the tool change. They command going to machine zero in Z and then X for the tool change.
What are M63, M64, M65, M66, and M67 doing? Along with all the moves prior to the G28W0 and G28U0 at the very end (I think you mean these are where it moves by the offset amount).
:9021(ATC)
G04X0
M05
G28W0 --Home Z before tool change
G28U0 --Home X before tool change
IF[#1005EQ1]GOTO100
IF[#4006EQ20]GOTO10
#25=1
GOTO20
N10#25=25.4
N20M06 --tool change
G98
G04P1000
G00U[800.400/#25]
M67
G04P1000
G00W[190/#25]
M63
W[-175.0/#25]
M66
G28U0
G28W0
M65
G99F[0.1/#25]
N100M99
orient tool for tool change Hall effect? Luslugger CNC Machining Centers 0 04-24-2009 06:24 PM
Mill PCB with cnc, optimise software BasicFox CNCzone Club House 0 03-26-2009 10:57 PM
re tool change/ little help please woffler Dolphin CADCAM 3 03-03-2008 03:24 AM
Very slow tool change on Tool Room Mill Capt Crunch Haas Mills 3 12-21-2007 12:20 PM
How to change Tool change position(About MAZATROL T1 control) liushuixingyun Mazak, Mitsubishi, Mazatrol 5 07-07-2007 02:58 PM
