Old 10-27-2009, 02:45 AM
rbcmetalwork is on a distinguished road
Fanuc 0i Mate-MB battery/batteries
I have a Sharp SV2412 with the Fanuc 0i Mate-MB control. I know where the backup battery is on the control unit (A98L-0031-0012). Are there any other batteries I should change? I'm new to Fanuc and don't want to lose any data or parameters.
Thanks,
RBC Metalwork
Honolulu, Hawaii
Old 10-27-2009, 03:03 AM
sinha_nsit is on a distinguished road
6V APC battery, somewhere in your electrical cabinet.
Old 10-27-2009, 06:32 PM
fanucman is on a distinguished road
just change them with the power on..
Old 10-27-2009, 08:32 PM
MysticMonkey's Avatar
MysticMonkey is on a distinguished road
*~~Darwinian Man, though well-behaved, At best is only a monkey shaved!~~*
*__________If you feel inclined to pay for the support you receive__________*
*_______Please give to charity http://www.oxfam.org/en/getinvolved_______*
Old 10-28-2009, 12:41 AM
Should EMERGENCY be applied, or it does not matter?
Old 10-28-2009, 12:53 AM
doesnt matter...
Old 10-29-2009, 01:09 AM
I still can't find the 6v battery. Here are pictures of the drive section if that helps. I can look into the drive from vents on the bottom but I don't see any battery.
ID:	92203   Click image for larger version
Old 10-29-2009, 06:01 PM
Trace the CXA2A cable this will lead you to the optional external battery pack
or CX5X to the Fanuc ABS Battery
The Beta i drives generaly have a battery cover attached to the two holes you can see in your photo
so it probably has the external grey box on the outside of the machine with FANUC written on it.
ID:	92255   Click image for larger version
ID:	92256   Click image for larger version
Old 10-30-2009, 12:31 AM
Nothing is connected to CX5X except for a small brown plastic part. It's only function is to keep the two pins from shorting to each other. I don't have a CXA2A. I do have a CXA2C though. CXA2C has blue wires running into the cable trays.
Randy
SV-2412, 0i Mate-MB
Old 10-30-2009, 12:48 AM
Is your machine an absolute encoder type or incremental type
post the values in parameter 1815
your machine might not have the 6V lithium ABS battery backup only the 3V Lithium Parameter/Memory backup
  #11   Ban this user!
Old 10-31-2009, 12:28 AM
check 1815 bit 5 for apc...
also do you need to do a zero return before running machine...
  #12   Ban this user!
Old 10-31-2009, 01:50 AM
Parameter 1815 shows all zeros.
Yes, I must home X, Y and Z at every power-up.
Randy
SV-2412, 0i Mate-MB
Fanuc 10M Parameters...no batteries spank Fanuc 3 03-29-2011 02:56 AM
Need Help!- Battery Replacement on Fanuc 0iMB syamin Controller & Computer Solutions 4 10-12-2009 12:10 PM
Fanuc amplifier 6v battery / Mach3 fomaz Fanuc 14 09-29-2009 10:59 PM
Strang Fanuc battery question timlkallam Fanuc 2 12-05-2007 05:52 PM
Fanuc O-TC Battery Alarm will not reset? valco Fanuc 2 07-17-2007 10:19 AM
