Old 10-26-2009, 11:02 AM
ZWM51 is on a distinguished road
threading trouble
Have a cnc lathe with fanuc o-t controller. Using a G76 threading cycle. I want to know how to controll first depth of cut and finshing depths of cut?
thanks,
zw
Old 10-26-2009, 05:53 PM
dcoupar's Avatar
The depth of the first pass is controlled by Q in the 2nd G76 block. The minimum depth of cut is controlled by Q in the 1st G76 block.
Old 10-27-2009, 02:31 AM
sinha_nsit is on a distinguished road
... in microns (in mm mode)
Old 10-27-2009, 11:40 AM
in english or inchs
Old 10-28-2009, 12:35 AM
It is least input increment.
So, it would be number of steps of 0.0001 inches.
This reminds me of another issue:
mm mode is 2.5 times more accurate than inch mode, in terms of least input increment. In other words, the resolution is better in mm mode.
Old 10-29-2009, 01:49 PM
Still cant control depth of cut. Changed second Q still doesnt change depth of cut. Keeps breaking threading insert on first pass. We're trying to id thread M14X1.5 in carbon steel. Here is the program trying to use. Can somebody look at make sure its right or send me a program.
T0202
S100M3
G00X0.514
Z.1
G76 P030160 Q002 R005
G76 X0.550 Z-0.9 P21 Q001 F.0590
G00X0.460
Z6.0
M30
Next question is their a possibility that a parameter is wrong or off for this not to work?
thanks,
Zw
Old 10-29-2009, 04:15 PM
dcoupar's Avatar
T0202
S100M3
G00X0.514
Z.1
G76 P030160 Q20 R0 (Q20 = 0.0020 MIN D.O.C.)
G76 X0.550 Z-0.9 P210 Q60 F.0590 (P210 = 0.0210 HEIGHT / Q60 = 0.006 DEPTH OF 1ST PASS)
G00X0.460
Z6.0
M30
Old 10-30-2009, 01:48 AM
R should be in inches. So, you specified 5 inches finishing allowance!
If you desire, you can specify some value for R in the program given by Dcoupar.
Old 10-30-2009, 02:02 AM
Incidently, the depth of metric threads is calculated by 0.61344 x pitch.
Bore dia = Outer dia - pitch
Root dia = Bore dia + 2*depth of thread
So, check your values, if you are making metric threads.
Old 10-30-2009, 02:32 AM
dcoupar's Avatar
I believe the actual height should be .0341
Name:	M14X1.5 Thread Info.jpg‎
  #11   Ban this user!
Old 10-30-2009, 06:08 AM
For ISO metric threads, the formula given in textbooks has been copied by me. The thread calculator software posted here does not appear to be using these formulae.
I am confused!
Are we talking about metric threads?
At least, difference of major and minor diameters should be twice of height.
Are practical values different from theoretical values?
  #12   Ban this user!
Old 10-30-2009, 01:03 PM
G76 INTERNAL THREADING
THANKS FOR THE HELP THE FIRST TELL U THAT THE SMALLEST CUT IT WILL TAKE IS .002
AND THE SECOND Q TELLS U THE DEPTH OF THE FIRST ROUGHING PASS WITCH WAS .006
SO SINCE IT IS .006 OFF BOTH SIDES IT SHOWS .0012 ON THE POSITION PAGE THEN IT TAKES .004 A PASS AFTER THAT UNTILL IT REACHES THE MAJOR DIAMETER WHAT CONTROLS HOW MUCH IT TAKES EACH PASS DOES THAT CHANGE WHEN U CHANGE THE THREAD HIEGHT
ID Threading Toddjones G-Code Programing 6 05-24-2009 12:46 PM
Need Help!- Threading on stepper to rod coupler trouble. Yodajammies DIY-CNC Router Table Machines 2 03-06-2009 08:25 AM
Threading ? Get lucky G-Code Programing 19 12-02-2008 06:01 PM
G76 threading Kai_DK Fanuc 13 01-28-2008 10:37 AM
CNC Threading metalworker Mini Lathe 1 10-31-2004 12:14 PM
