Can someone with an 0i control for a mill post these macros? Thanks Custom Macro B Canned Cycles The Custom Macro B canned cycles are fully tested examples of macros that you can use immediately, or copy and modify to implement your own custom cycles. O9170 Outside frame milling O9171 Inside frame milling O9172 Pocket frame milling O9173 Face milling O9174 Outside circle milling O9176 Inside circle milling O9177 Pocket circle milling O9179 Slot milling O9180 Row pattern drilling O9190 Rectangular frame drilling O9280 Bolt-hole circle drilling % O9170 (G170 OUTSIDE FRAME MILL) #2=#4003 (G90/G91 MODE) #130=#5041(INITIAL X POS) #131=#5042(INITIAL Y POS) #132=#5043(INITIAL Z POS) #133=#[2000+#4107](ACTIVE RADIUS) IF [#2 EQ 91] GOTO 3 (INCREMENTAL MODE) #130=0 #131=0 #132=0 N3 #130=#130+#4 (FINAL X POSITION) #131=#131+#5 #132=#132+#6 (FINAL Z POS - R PLANE) IF [#13 NE #0] GOTO 4 #13=0 N4 #7=#7-2*#9 (LENGTH - RADIUS) #8=#8-2*#9 (WIDTH - RADIUS) #9=#9+#13 (RADIUS+FINISH ALLOWANCE) IF [#14 NE #0] GOTO 5 #14=#12 (FINISH FEED) N5 IF [#15 NE #0] GOTO 10 #15=0.5*#12 (PLUNGE FEED) N10 IF [#16 EQ #0] GOTO 20 (STEP DEPTH) IF [#16 EQ 0] GOTO 20 #23=#10/#16 #17=FIX[#23] (ROUND OFF) #23=#10-#17*#16 IF [#23 EQ 0] GOTO 25 #17=#17+1 (NO. OF STEPS IN DEPTH) GOTO 25 N20 #17=1 #16=#10 #23=0 N25 G90 G00 Z#132 (MOVE TO R PLANE) G00 X#130 Y[#131-#8/2-#9-#11] (START POSITION) G41 G91 G01 X#11 F#12 G03 X[-#11] Y#11 R#11 (START OF MILLING CYCLE) N1 WHILE [#17 GT 0] DO 1 IF [#17 GT 1] GOTO 18 IF [#23 EQ 0] GOTO 18 #16=#23 N18 G01 Z[-#16] F#15(PLUNGE) G01 X[-#7/2] F#12 (MILL) G02 X[-#9] Y#9 R#9 G01 Y#8 (WIDTH) G02 X#9 Y#9 R#9 G01 X#7 (LENGTH) G02 X#9 Y[-#9] R#9 G01 Y[-#8] G02 X[-#9] Y[-#9] R#9 G01 X[-#7/2] #17=#17-1 END 1 N19 IF [#13 EQ 0] GOTO 30 (START OF FINISH CYCLE) #9=#9-#13 (DECREASE RADIUS BY FINISH ALLOWANCE) #11=#11+#133 (ADJUST CLEARANCE BY TOOL RADIUS) G03 X[-#11] Y[-#11] R#11 G01 X[2*#11+#13] G03 X[-#11-#13] Y[#11+#13] R[#11+#13] F#14 G01 X[-#7/2] (FINISH) G02 X[-#9] Y#9 R#9 G01 Y#8 (WIDTH) G02 X#9 Y#9 R#9 G01 X#7 (LENGTH) G02 X#9 Y[-#9] R#9 G01 Y[-#8] G02 X[-#9] Y[-#9] R#9 G01 X[-#7/2](END FINISH CYCLE) #11=#11-#133(ADJUST CLEARANCE BY TOOL RADIUS) N30 G03 X[-#11-#13] Y[-#11-#13] R[#11+#13] F#14 G40 G01 X[#11/2] G90 G00 X#130 Z#132(Z MOVE UP) G#2 (PUTS BACK INTO G90/G91 MODE AS FOUND) M99 % |
| Sample Fanuc Tool change macro | dpuch | G-Code Programing | 6 | 06-01-2011 08:13 PM |
| sample item. | ihavenofish | Novakon Systems | 5 | 04-24-2009 09:34 PM |
| Testing program for Macro (Fanuc Macro B) | NickDP | Fanuc | 2 | 03-27-2009 03:15 PM |
| Convert Fanuc Macro to Fadal Macro | bfoster59 | Fadal | 1 | 11-08-2007 11:41 PM |
| A sample tool change macro. | gar | Haas Mills | 17 | 08-22-2005 05:13 PM |
