Old 10-22-2009, 01:13 PM
Apollopeon is on a distinguished road
Question How do I cancel a G92 on the fly?
Hello everyone. I just got a refurbished toshiba mill with a Fanuc 32i controller. Does anyone know how to cancel a G92 on the fly? I was using a Tosnuc 888 and it was just a matter of a G53 and recalling the fixture offset. This isn't working for me on the Fanuc.
Any help would be appreciated.
Thanks.
Old 10-22-2009, 06:45 PM
memoryman is on a distinguished road
you can use a fly swatter. I have never seen a g92 on a fly.
Old 10-23-2009, 02:04 AM
sinha_nsit is on a distinguished road
It remains effective only in the current machining session. So, cycle power to cancel it.
Old 10-23-2009, 07:35 AM
beege's Avatar
beege is on a distinguished road
I think you can:
G28G91Z0
G28G91X0Y0
G90G92X0Y0Z0 (or whatever your numbers are supposed to be at "home".
Old 10-24-2009, 03:15 AM
You are right.
In many cases, Home is not (0,0,0). So, you have to remember (and type) the coordinate values at home position.
Is is not simpler to cycle power? Of course, when you want to cancel it in the same program, you cannot cycle power! But such requirements are likely to be rare.
Old 10-30-2009, 11:31 AM
Mitsman is on a distinguished road
G53Z0W0
G53X0Y0
G92X0Y0Z0
Should work.
Old 10-30-2009, 12:32 PM
Andre' B is on a distinguished road
I got some Mit wire EDMs and they set the G92 location to the current position every time you hit the reset button.
I just put a line at the to of every program.
G53G92X0.0Y0.0
Old 11-04-2009, 01:57 PM
PJPowers is on a distinguished road
I have found that not all controllers will allow you to easily cancel a G92 move. One code I found to work on at least one controller was:
G92.2X0.Y0.
or
G92.3X0.Y0.
We have a Northwood Router at my shop that we program with AlphaCAM and the post file that Northwood built for it used G92 for sub repeats. So I called Northwood to ask how to cancel the G92 move out because the G92.2 and G92.3 moves did not work. After sitting on hold for about a half an hour they finally came back on the line and said "You don't ever want to use a G92 move on that machine because it could cause it to crash!!" So what ever I modified the post that Northwood built for us to use G52 instead, and it works flawlessly.
Old 11-05-2009, 12:45 AM
I am not sure, but G90 G92.1 X0 Y0 might work on Fanuc. Somebody may try and report the result.
Tags
g92
How i cancel G92 command? shaikaa1 Haas Mills 6 02-28-2009 08:37 PM
How Do You Cancel an Ad on CNCZONE Gene-Yo Forum Questions or Problems 1 01-29-2009 08:45 PM
Cancel a Posting Mr.Chips Forum Questions or Problems 7 01-16-2007 05:35 PM
Effect of T0 (tool offset cancel) HuFlungDung CamSoft Products 5 09-01-2006 03:58 PM
tool offset cancel problem zoeper Machine Problems, Solutions , Wireless DNC, serial port 8 04-25-2006 10:46 AM
