Old 10-22-2009, 07:47 AM
800XCR is on a distinguished road
Fanuc 10T startup problem
Mori Seiki TL-40 with Fanuc 10T. I am getting a "PC 010 PC ERROR" alarm during power up most of the time. Fanuc says I need a new memory cassette which costs about $3500. Is there a less expensive way to correct this? The last line displayed during the start sequence before the alarm is "Loading PC Parameters: End"
Old 10-22-2009, 09:47 AM
Al_The_Man's Avatar
If this is the PMC cassette, Fanuc usually load the PMC in from the Eproms in the cassette and then run the ladder from ram memory.
I have picked up a cassette off ebay for $16.00, but you need to transfer your eproms over, if it is the eproms themselves then you are out of luck and would need to obtain a fresh copy of the ladder in eprom.
Old 10-22-2009, 10:27 AM
Thank you, I will try that.
5020L startup problem rick kroeze Okuma 3 07-31-2009 02:36 PM
KM3P problem startup jimc80 HURCO 2 07-09-2009 01:38 PM
HAAS VF1 Startup Problem rkdygert Haas Mills 8 07-24-2007 06:59 PM
Startup Problem StormWerkz Fadal 14 03-06-2007 09:57 PM
Hurco BMC 20 startup problem tirebiter Machine Problems, Solutions , Wireless DNC, serial port 3 11-08-2006 04:50 PM
