Hi. I try not to ask the soon I have a problem but I cannot see an solution to this. I have a 21i-M controller, and when I issue a: G01 X1Y1Z1 I get an error alarm: 015 Too many axis commanded I looked at the parameter manual and I see that parameter 1010 is the number of axis commanded. It was already set to 3. I cannot find any more cross reference to this issue or parameter, so I realy do not know what can I try more, but I think is hard to belive that an expensive control cannot handle 3 simultaneus axis. But who knows ... Thank you for any comment |
| Specifications for Axis on 21i-MA
__________________ *********************************************************** *~~Darwinian Man, though well-behaved, At best is only a monkey shaved!~~* *********************************************************** *__________If you feel inclined to pay for the support you receive__________* *_______Please give to charity http://www.oxfam.org/en/getinvolved_______* *********************************************************** |
| That is right. This morning I have done that. A program instead of having 100 lines will have 4000, but it works fine. If we pay attencion we can see the machine jumping a little bit, but if the machine is rigid the final part turns out as I had the 3 axis movement. Drip feed is then a must since programs get quite large. |
| the Difference of 2-Axis and 3-Axis of Vertical Mill Machine | begacon | Knee Vertical Mills | 6 | 07-30-2009 06:31 AM |
| Compare Catia and MCX2 for multi axis lathe/4 axis mill | bob1112 | General CAM Discussion | 0 | 10-10-2008 07:15 PM |
| How can I coupling a stepper motor axis directly to other axis? | meknik2001 | Stepper Motors and Drives | 4 | 05-08-2008 01:54 PM |
| One axis (z-axis?) computer controlled testing device | TsThorsell | Stepper Motors and Drives | 3 | 02-07-2008 12:38 PM |
| New Design - Hybrid 3-Axis Router/4-axis Foam Hot Wire Cutter | the__extreme | CNC Wood Router Project Log | 3 | 02-26-2007 02:58 PM |
