My control keeps getting stuck at the following line: G0 X.3096 Z1. (RAPID TO 1 INCH FROM FACE) When it stops here I get a "003 TOO MANY DIGITS" alarm. According to the alarm code list this means I have entered too many digits. Very helpful. Anyone run into this before? Bob J |
Apologies for the tardy reply. I was out for a couple of days and by the time I returned an operator had butchered the program so badly the alarm problem became moot. It seems that leaving the edit key in is a license to kill. After rewriting the program I didn't have the issue so I am assuming it was either an input error or one of my descriptions was to long. Either way it is a phantom until it occurs again. Thank you for your suggestions and responses. Bob J |
Possible you had the program line numbers going above the 9999 that is the usual Fanuc default amount, if for example you have a program where you set the numbers to go in increments of say 10 to allow for editing at the machine it is easy to end up with numbers that go above the 9999 limit and that will bring up the P/S 003 alarm. Could be when you re-wrote the program you set the line number increments to a smaller amount so didn`t hit the magic 9999!! Regards Rob ![]() ![]() . |
| G-Code output precision always 3 digits? | cwm9 | SolidCam | 11 | 11-10-2009 01:01 PM |
| Need Help!- DAEWOO 8 Steady rest pressure alarm, External feed hold alarm | doubleeagle | Daewoo/Doosan | 4 | 06-12-2009 03:15 PM |
| Need Help!- Hardinge CHNC 4-16C Alarm 2009 | Billet Sean | Hardinge Lathes | 4 | 03-18-2009 05:16 PM |
| Alarm 1006 on hardinge lathe | TARIQ08 | Hardinge Lathes | 7 | 09-10-2008 07:33 AM |
| Dialog Digits | MikeT | BobCad-Cam | 2 | 03-02-2004 08:07 AM |
