I think you don't need to set the position. The home position is defining by the switch. Controller sees when this switch being swithed and then looking for Zero signal from encoder. This sets up the machine zero.
If "machine zero" not there where you need, move your switch.
If "soft overtravel" alarm occurs, cancel soft limits in IPL mode and then home your axis.
LinkBack URL
About LinkBacks
