Results 1 to 9 of 9
Thread: Fanuc servo vibration noise Z-ax lathe
    Apr 2008
    Netherlands
    We just got a 1990 Puma 10S lathe with a Fanuc
    15 controll. Overal state is good, it has about
    9500 cutting hours and guides are fine.
    The Motor of the Z-ax is a Fanuc 10S-2000 rpm
    (same name as the Puma by coincidense) and it is making
    a lot of noise, vibrations in the Z servo make the machine noisy.
    Accuracy is fine but when you feel the servo it is really
    vibrating unlike the same motor on the X-ax.
    There are no error messages and accuracy is good.
    I hope someone can give me some ideas about what
    to check. I already changed the servo gain from 3000 to
    1800 but this didn't make any difference.
    Richard
    Feb 2009
    vibration
    Check the ballscrew thrust bearings. Binding there will cause servo problems. Check run-out on the B/S coupling, if all good pull the motor out and rotate by hand. Should feel smooth with no notchyness at all.
    Apr 2008
    Netherlands
    Oke thanks for your suggestions
    I already checked the spindle bearing, it has no backlash
    in Z direction but the ballscrew nut has backlash,
    about .04 mm. I have seen machines with 0.1 mm balscrew
    backlash with not any vibrations and noise in the servo at all.
    But I will check the radial clearance of the spindle bearings
    and the other things you suggested.
    I also get an error 12 after switching on the fanuc display.
    But there is another button that I have to press for about
    2 seconds and after that the error 12 is gone and the hydraulic
    pump starts.
    I know error 12 but this error is not on the spindle drive display.
    So could it be an error on the Z-ax servo drive? I cannot see
    this message on the servo drive as there is no display on the
    servo drive.
    Could it be a half broken servo drive or should'nt it work at
    all if it is a 12 error? Could a servo drive work if one of the
    transistors is broken? I cannot see on what servo drive the
    error 12 is as I only have a 2 digit display that shows errors.
    On the display of the Fanuc 15TF there is not any alarm message
    at all.
    Thanks,
    Richard
    Feb 2009
    vibration
    You are confusing me. You said vibration on Z axis motor, yet you are checking spindle bearings and spindle drive ???
    Apr 2008
    Netherlands
    Oke I see this is confusing.
    It is only about the Z bal screw, I called this spindle.
    It is not about the Spindle with the chuck, that is all fine.
    May 2009
    is the x axis motor the same part number... if yes
    swap the command and feedback cables to see if its the motor or drive
    Apr 2008
    Netherlands
    Oke good idea thanks.
    I try that next week.
    Apr 2008
    Netherlands
    I have checked the bearings and couplings with a micrometer
    and they seem to be fine. If I am pulling with about 300N
    I only see 0.01 mm of deflection, it doesn't look like play.
    I found something more. I enabled the setting to load the
    default servo parameters. After that the Z-axis didn't work
    anymore at all with a certain error message.
    After searching I found the wrong motor was adjusted in the
    Fanuc 15 settings.
    After setting the right motor the Z-axis works again.
    After loading the default servoparameters from Rom there are
    vibrations when the Z-axis is moving and
    before it was only when the Z-ax didn't move. So I guess parameters
    definately have a big effect but simply changing the gain didn't
    make any difference at all. The parameters that were changed because
    of setting the correct motor sure have effect but it still isn't wright
    I have many settings like current gain, Velocity gain, feed forward
    position gain. I know what they do but I don't know where to start with tuning.
    Trial on error could be very timeconsuming.
    This is a Fanuc 15A and unlike a fanuc 15B which has waveform diagnosis function
    this Fanuc 15A doesn't seem to have this.
    So I wonder how I could check response of low level parameters apart
    from listening to the vibrations.
    If the motor is positioned and in servo loop and I pick the coupling and try to
    turn it it starts with making a lot of noise and it vibrates with a high frequency.
    You always feel some vibration when trying to displace a servo on power but
    the Z-ax is just wrong when comparing to the X-ax.
    I see in my parameter manual
    For details on digital servo parameters, refer to HAC Servo Unit
    Maintenance Manual (B–65005).
    Could anyone please help me with this manual? Is it available
    in PDF format?
    Richard
    Apr 2008
    Netherlands
    A Fanuc specialist fixed the problem.
    There was an inertia ratio parameter, in the manual
    they said if you don't know the exact value make it zero.
    Other Fortune lathes with Fanuc 15 controll also have
    this on zero.
    The inertia ratio was adjusted to 0 and the current
    gain was changed a bit. That made the servo absolutely
    quiet again. The coupling seemed the cause in first
    instance but after changing the parameters it was
    absolutely quiet.
    1. Problem- Servo alarm 414 Harrison ge fanuc Alpha 400 lathe
      By davide.castro in forum Fanuc
      Last Post: 10-20-2008, 11:42 AM
    2. Replies: 2
      Last Post: 06-03-2007, 09:21 AM
    3. servo motor vibration
      By tkh60 in forum Plasma, EDM and other similar machine Project Log
      Last Post: 05-09-2007, 03:47 PM
    4. servo noise
      By johnmckeown in forum Fadal
      Last Post: 12-04-2006, 01:24 PM
    5. Vibration in X axis of lathe
      By sab in forum General Metal Working Machines
      Last Post: 05-19-2006, 03:57 PM
